That's a very common problem we see here. Same issue.We also noticed when we turn the dryer on, it creates a vacuum as well.
I believe the OP said great room.I don't think the fireplace is in a bedroom?
Doh, confused this with another thread. Never mind.I don't think the fireplace is in a bedroom?
 The fireplace ash dump has a little door inside that connects to outside air. You can see a vent in the brick from the outside. This will let in fresh air but presumably need to keep the ash dump door open for this air to come in. When doing so however, there is a small wind and ash blows around and into the room.
it does not allow it at all.I'm a bit surprised that code would allow a fireplace in the bedroom of a tight new house, especially without an outside air supply.
It is not an ash dump it is an air intake with an ash dump door over it we see them all the time. The problem is that they simply do not supply enough air to make any difference.'m not sure that could be classified as a fresh air intake, since it sounds like the ash dump door needs to be open for it to let air in - and I don't think you'd want to burn with the ash dump door open?Actually, likely wouldn't want it open at all except when dumping ashes? Definitely sounds like a setup I haven't seen before.
Me too. If it's a fossil-burning furnace that vents outside and takes from inside, that's just one more source of negative pressure. If it's just a circulating electric furnace like we have, it shouldn't be a problem.Also curious what the primary heating source is.
I just re read the op and you are right it seems like they have an ash dump that has fresh air supplied to it in some way. I have seen that occasionally as well but not as common. But regardless even if the vent was the size of that ash dump door it would not be able to supply enough air.OK - I will certainly take your word for it. I was just going by what was previously posted.
Would like to see a pic though, just not quite picturing it in my head.
Our pre-fab Heatilator ambiance appliance has an outside air intake with a flapper door you open when burning - it's only a 4" hole & pipe. Pretty sure it pulls most of the air from the warm living room through the glass door gaps & other vented locations.
stevenriz-
In our house I crack a window for the 1st few minutes when I'm starting a fire. If not, there's a chance I'll get a smoker (alarms going off and bunch of smoke in the house). I also make sure there's no bath fans or cooktop fan running. Once I get the fire going I close the window and don't worry about the fans.
Did you find out the purpose of the exhaust fan in the laundry room? Having a fan running all the time does not make sense. You said you found the switch for it, which is good. Just curious what the purpose is in a new house.
But I gotta ask: How many stoves and how much wood? Just being devil's advocate here (in jest)...Every time I read one of these threads, I think life in my inefficient old house isn't so bad. Two stoves, dryers, range hood, bathroom exhaust fans, radon systems... all running at the same time with no issues.
 I hope to publish those numbers this spring, if we get a good (read "normal") winter, this year. With two Jotul Firelights, I was doing 10 cords + 1000 gallons oil + $250/month electric (lighting and heating together). I believe my numbers are lower with switching to two BK's, but last year was so freakishly warm that I wasn't able to gather any reasonably comparable data.But I gotta ask: How many stoves and how much wood? Just being devil's advocate here (in jest)...
