maple1
Here's a link that gets to the issue I was discussing:
The fuel that generates heat within a wood burning stove is obviously firewood. Wood burning stoves are often less efficient when it comes to an equal balance of fuel to heat release because the outside of these types of stoves don’t typically have an efficient heat exchanger. A heat exchanger is a piece of the equipment on the stove that helps transfer heat from the stove to the rest of the room. Heat exchangers on wood burning stoves don’t have the surface area for the proper extraction and distribution of heat relative to the amount of fuel used to generate the heat. Wood stoves are much more combustion efficient then they are heat transfer efficient.
(broken link removed)
I suggest that a fan directing room air against the hot combustion chamber improves the ability to extract heat from a wood stove, especially when it's running hot. I don;t see that it would matter whether the air was directed against the hot combustion chamber at the front or the back of the stove.
A fan across the front might pull heat off the stove, sure. But it wouldn't do it as well as a factory fan kit. Much bigger HX area drawing from the back & top, than just the front.
