New Hearth Pictures For My Breckwell P23
ktfinch2000
67
Coventry, Rhode Island
Total cost $85 bucks. Knowing I saved $300+ Priceless!!
Materials used
2 layers of 3/4" cdx plywood
1 layer of 3/8" Durarock
1 layer of slate tiles
Wrapped in Mahogany
Total height 2 3/8"
3 hours from start to finish
Let me know what you guys think something like this is worth. I own a custom cabinet shop and was thinking of making these to sell. Thanks
  • New Hearth Pictures For My Breckwell P23
85.00 well done!
Beautiful - I just used the same slate for my hearth. I really like your wood border.
The slate is so easy to cut that I'm working on making receptacle covers out of it.
Would be a nice touch for the outlets behind the hearth.
'Frank
'Frank
That looks great!
I have a central air vent in the corner so I had to notch out the hearth and I just mounted the vent cover over it. Not much else I could do without moving the vent in the basement
'Frank
Hello Frank,
I am working on redoing my hearth with slate. I'm new with working with slate. What method do you use to cut slate? Thank you.
I used a wet saw, the same you would use for cutting ceramic or porcelain, but the slate is so easy to cut that I'm sure a glass-cutter type would work well.
You can buy a wet saw at HD for $70 and it will work great. I have about 4 jobs on mine and still going strong. So I'm ahead of the rental curve.
I had to make 2 of the stones in my mosaic border to get the pattern to match up. I just traced and cut the shape, then used sand paper to round-over the edges.
'Frank
HI,
It looks really wonderful. :coolsmile:
Did you build it in or make the pad freestanding? We were going to build ours in with 2X4's turned on their sides and OSB under the durarock. Is there a reason that you did not use OSB and that you made your base completely solid? We have slate that we removed from an entry that was turned into a closet.
Sandy
I wanted something sturdy and solid. Just my way of doing things. I like to use cdx plywood because I think its better than osb but you will be fine doing it the way you explained. I used a wet saw to cut the tiles and it worked great. I built the unit in my shop then put a few dabs of clear silicone on the floor before I placed the pad over it just so it does not move. Not really needed because the stove is heavy but I did not want to here any squeaks:)
