When the retro kit was installed in my boiler in an effort to correct the “burnpot bubble issue,†the 10 RPM auger came with the kit. Does your boiler have the 10 RPM auger without the pressure ignition?
Glad to see you join the post Wil, I have read pretty much all your posts on this and other forums with your experiences with the PB105 which have helped a lot.
I have the Gleason Avery 6 RPM auger motor with a date tag of 2005. I would think the pressure ignition would work with either motor unless there is a physical size difference between the two that would prevent installation with the older motor.
Was there in increase in pellet consumption with the newer motor since it turns faster or was the control board updated to run the auger less than with the 6 RPM motor?
