Supposed to b cooler this weekend in pa anyone thinking of burnin
Looking at the forecast (cloudy, lows 40s, high 64)... I'm thinking I may be pouring pellets with my coffee on Sunday morning. Maybe even on Saturday.
YES GOOD IDEADo ya think I should fire mine up and make sure of fumes since it was only test fired once. Cause it will still b warm enough to open windows or is one test fire take care of paint fumes
I could dump that often.. but even at a 'higher' setting (FEED RATE 3 / STOVE TEMP 3 - 4), I can go for an entire week before emptying. (maybe because I was using a relatively 'lower' ash type of pellet??) I'm hope that will still be the case when I finish burning my Barefoot and attack my stacks of LaCrete.... to be determined around December or so![]()
wow...i dont see any selling for below 270 here in CT.$215.00 How do you like them?
Really - wow! I am expecting a slight decrease with the LaCrete brand.... anything more than slight than I'll be happy for sureI expect you'll be shocked in the ash difference between those two. I'll say no more.
Have u tried wood pellet co before.do u think they are a bad pellet.i hope there good cause I'm stuck w 6 tons otherwiseI expect you'll be shocked in the ash difference between those two. I'll say no more.
Wow 6 tons of one pellet at one time.... that's a leap of faith!Have u tried wood pellet co before.do u think they are a bad pellet.i hope there good cause I'm stuck w 6 tons otherwise
I knew barefoot was good - I only switched to lacrete because my original pellet supplier was still only taking orders for barefoot as late as August (which were also $20/ton higher than last year at $295/ton now) once he finally gets them in! I heard too many things about last season's shortages so I decided not to put off buying 3 tons any longer and went with getting 3 tons of lacrete delivered in July at $309/ton.
