New to this forum so I'm not sure if this is the right place to post this or not. I'll be happy to repost somewhere else if needed. Copy and paste is easy
![Wink ;) ;)](/talk/styles/default/xenforo/smileys/wink.gif)
I'm considering replacing my current wood burner with a heat commander but I'd like to get some feedback from some more knowledgeable people to make sure that it will work for my application before I take the plunge. I read through the first 4 or 5 pages of this thread, as well as the last 5 or 6 pages, and it seems like the Heat Commander is turning out to be a pretty good unit.
I currently have a circa 1980 Energy Mate add-on wood furnace (wood furnace, NOT a wood stove). Its pretty similar to a Clayton in design. It has a forced air draft which has had the motor removed because it died. The draft has an adjustable cover that blocks the opening. Over the years, I've learned to set the draft based on the expected outside temperature and I can normally keep it pretty close to 71 degrees all day long. I'm heating a 2000 sq ft brick ranch with a full basement that was built in 1959. I'm still in the process of replacing windows, so it's pretty drafty. Temps get down around zero (F) in the winter, but they vary quite a bit. On rare occasion, it might get down into the negative teens, or even -twenties, but that's rare. Daytime highs vary a lot also. Anywhere from single digits up into the 40s. Typically, on a sunny day, I let the fire burn out if the temps are going to climb above 35 deg. I might add a couple of small pieces that morning, but my aim is for the fire to go out before noon, or at least down to a small pile of coals.
My current wood burner is in the basement. It has a 10" duct that comes out of the top, turns 90 deg, and then runs about 5' horizontally over to the cold air return on my NG furnace. It feeds in above the air filter. I normally set the house thermostat at 68 deg so that if the wood burner cools off, the NG furnace will kick on and keep it from getting too chilly. I fire it in the morning around 5:30 am, top off if needed around 7, then I don't see it again until 6:30 or 7pm and there's normally a decent bed of coals left to work with. On colder days, I have my son or daughter put 2 or 3 small rounds in around 4 PM. Normally I'll put a medium size fire of smaller splits at 6 to get the house warmed back up quickly, and then add a few medium size splits/rounds in the 6" range a little later before finally topping it off for the night around 11pm. I go through 3 to 4 cords of firewood per season. I burn mostly seasoned hickory, but I also burn some red oak, and a mix of less hard wood like ash and walnut as the opportunities occur.
So now for my questions
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
On a cold day, should I expect to be able to get 9 or 10 hrs of heat out of an HC? From a cold start, how long does the HC normally take to get the heating system up to full temp? How long of a burn will the HC provide on a warmer day? How does the HC do on the warmer start/stop days where I'm only burning of an evening/night?
Last question is how hard is the HC to get down a flight of stairs? My guess is that with the fire brick out, it's still a pretty heavy unit and it may just be too dangerous to take down a flight of stairs. I'm considering digging a pit and adding an external entrance to the basement where I currently bring my wood it, but that adds significantly to the cost of this project
Thanks,
Mark
