Todd67
The 36 inch clearance was required when the stove was built. NFPA came up with 115* f. over ambient temperature as the benchmark maximum surface temperature which is used by UL. So at 70* room temp, combustible materials surface temp cannot exceed 185*. The testing is done with thermocouples mounted on moveable walls. Stove is over fired with oven dried softwood stapled together in bricks called "Firebrands". This is what determines clearances. Not the manufacturer.
What makes it more dangerous is TIME.
When first installed, the moisture content of building materials is high, with high ignition point temperatures. The longer it is dried over time, the lower the ignition point becomes. If you take a piece of wood and continue to dry it under your stove for a period of time, you will find you can light it very easily. Just like charcoal from the rear of the stove that is raked forward. All the moisture has been released, and it will burst into flame very easily when raised to the temperature of the coals.
The only thing I see wrong in your picture is the window trim and sill, possibly less than 36 inches to stove surface.
When burning at your maximum temp, see what temperature the wood is. This will give you an idea how close it comes to the 115* over ambient benchmark. I use an IR thermometer all the time to inspect cases like this. Check the cats and dogs temps too. Amazing how hot stove dwellers can get.![]()
Thanks for the detailed explanation!
That window trim was a concern for me at first, but these windows are so drafty that the window trim stays cold, well under 90*. When the wind blows outside, the curtains and blinds move inside. As for the animals, they're always warm to the touch
