Well 28 degrees and a blizzard. The M55 is back in service today..
Not nearly as bad here, but low 40s has the stove running too.
Another year and still going strong. Gave it a good cleaning last night.after reading yours, I decide to buy the same one![]()
Overachiever you....You have a ways to go to catch my Envrio ef3
in its 22 season, only ever replaced circulation fan
Runs 24/7 from mid-November to the middle of April
Keep your stove clean and it will keep you warm
Wow - I think you just solved the mystery and maybe I don't have to pull it out again!What mode are you running the stove in?
Manual --Thermostat connection terminals must have a jumper installed
Hi/Low -- requires a thermostat
On/Off -- requires a thermostat
Sounds like you have the stove set in Hi/Low and without a stat it will
only burn in low no matter what you set the heat at until the stat calls for heat
then it will ramp up to whatever the heat setting is at
As it is a new stove you should have a manual if not here is one
Welcome to the forum
NOTE READ THE WARNING ON PAGE 10 ABOUT THE AUGER COVER ADJUSTMENT
