New Effecta Lambda 35kw install with 1000gal storage
Bill1472
29
Michigan
Starting our second Effecta install, The tank went in today 41" 1000gal propane tank
had to put through a 45" door, everything went as planned, will post more pics as the install
continues. Will be a forced air setup at the moment, with plans for baseboard and in floor
heat at a later date.
  • New Effecta Lambda 35kw install with 1000gal storage
more pics of the install
and more,
Looks like you have a nice big boiler room. Nice to have that machinery to move the tanks around. Are you plumping with copper or black iron. Lots of work .
How are you insulating the tanks.
Huff
We will use mostly copper$$$, We used supper Tuff-R on my effecta system, I like to take a panal off to show somone that has an intriest, I dont like foam spray to cover the tank. I will keep picks of the progress as we go.
Bill,
Looks like you are doing a great job. Is that a bladder expansion tank? Randy
Bill,
Glad to see ANOTHER effecta lambda 35kw system being installed. Doesn't that make (3) in East Jordan, MI alone?
Those 1,000 gallon propane tanks are a bear to handle but with the proper equipment it's quite easy (WHERE THERE'S A WILL......THERE'S AS WAY!)
No one can argue that this is probably one of the best recycling efforts occurring today (taking an old, obsolete 1,800 lb, 250 psi @ 650 F pressure vessel and using it to accumulate and store 130-200F water at 15-20 psi).
Can't wait to see photos of the entire setup as it is being installed.
Keep us posted on your nice work!
Brian
Regarding my user name, NO, we did not lose our agent status.
That statement couldn't be further from the truth - we have 13 effecta boilers (and 13 very happy customers) in North America and are working on the next order of boilers.
The reason for the name change came at the request of the higher powers at hearth.com
Brian
Hello Everyone,
new here to hearth, but you have already heard about the new boiler installation.
Effecta Lambda 35kw w/ 1000 gallon of storage
Bill is my father-in-law and i thought i would update some photos....
first pic... tanks rolled in on carts
second pic... 1000 gallon tank set, insulation board put up and bottom drain added as well
close up of bottom valve
1000 gallon tank plumbing underway
1st.. blank slate
2nd.. drop tube valves
3rd.. nice "little" long view w logo :)
And Finally unwrapped the Effecta Lambda 35!!
Set in place and plumbing began on it as well...
and bottom inside view too
that makes you up to date as of 2/20/12
Thanks for viewing and more pics to come.
Welcome Gene,
Looking good. You will probably be sad to see winter end just getting that nice boiler. J.T.
Thank You,
It has been quite the learning experience so far, I'm by no means versed in Boiler systems, however i have been using wood stoves for awhile. The first time i watched Bill fire up his Effecta 35 i was completely amazed.. I never could imagine burning wood as being so easy and hassle free. I probably spent about 1-2 hrs a day just feeding and meddling with my woodstove, burned over 26 cord a winter on a house that was 1400 sq. feet.. Really??? you might ask yourself... The sad truth is yes.. ha. Recently my wife and I bought a new home, much larger, and i am so completely stoked to be working on the new Effecta 35 w/1000 gallons instead of some other yard smoker that so many around here have. But the Good news is that this will make 3, ya 3 Effecta 35's in East Jordan, MI.. that's pretty awesome.
Pfft. Talk about stoked, there's four Ford 3/4T pickups on just the road I live on. Top that!
Gene.EJ said:
Thank You,
e. I probably spent about 1-2 hrs a day just feeding and meddling with my woodstove, burned over 26 cord a winter on a house that was 1400 sq. feet.. Really??? you might ask yourself... .
26 cord? Really.
Unless your definition of a cord is different than mine I don't see how you could burn that much in one stove in a year. When I burned 24/7 in my jotul f600 I went through at most five cord.
Welcome to the site!!!
If you guys would ever have some snow up there I would come check out you system. Kinda hard to ride the sleds on dirt!!!! LOL
Glad to see Brian hooked you up with a real nice boiler.
Take care,
Rob
lol, thats awesome too!
