RustyShackleford said:learnin to burn said:If double wall do you have the stove adapter or are you trying to put the double wall pipe right into the stove?
I haven't gotten mine yet, but I was told that double-wall pipe (Simpson or Selkirk)
SHOULD fit directly onto the stove (with no adapter). This by a tech at BK ...
learnin to burn said:Congrats on the first fire....
I know the selkirk requires an adapter for the King. Although I did modify a telescopic length to fit the collar. The King collar is 1/4" wide and the outer wall of the pipe almost falls into it. I think the collar on the princess is also 1/4"
I keep hearing conflicting info on this. I know single wall works fine, but I'm still not sure what I need to order for the Selkirk double wall. I was told by BK that an adapter might be needed because the 1/4" thick collar. They said to call Selkirk. I've called them 3 times now and I'm yet to receive a return call.learnin to burn said:Congrats on the first fire....
RustyShackleford said:RustyShackleford said:learnin to burn said:If double wall do you have the stove adapter or are you trying to put the double wall pipe right into the stove?
Called for a clarification, and he said that the adapter IS needed for the cleanest
install, but, simply to save the cost of the adapter, many folks will simply crimp the
inner wall so that it fits inside the collar, and trim the outer wall.
He also said something interesting, which is not in the manual. I asked about clearances
to NON-combistibles (e.g. a stucco'd cinderblock wall). Theoretically they could be ZERO,
right ? He said it was a good idea to leave more than that, perhaps 4-6", because
radiation off of the cinderblock wall would trick the thermostat, so that it would not
re-open properly when the stove starts to cool down, due to radiation from the wall.
