Good evening everyone (and Happy New Years Eve!). First time posting on the forum here, but I’ve been browsing, researching and learning for almost two years now. I just finished installing a BK Princess Insert earlier this month, and it’s lived up to all the hype so far. More to come on the install in the near future, which ended up being a custom perlite/Roxul/block off plate/top plate adventure, and I think you’ll enjoy the write up (and all the pics). Hopefully it ends up being a value-add to the next guy. I know I couldn’t have done it without all of the existing threads and posts on this site.
Alright, onto the issue I’m facing now. I’ve probably thrown the bypass lever ~30 times so far. Up through time ~25, everything worked as expected. Smooth action, sets firmly into place as the bypass closes and begins to seal, cams over with a satisfying click/pang into the lock position. Very nice, great success. However, time ~26-30 has become increasingly gritty/rough feeling throughout the entire throw, and it is no longer clicking/panging into that cam-lock position (or at least it doesn’t sound like it’s making it there, though the handle seems to be up into the fully closed position). The stove still seemed to run fine/normal, and I let it burn out the last time and left for vacation. I’ll be heading home tomorrow to some New England winter weather (for the first time this season, though I’m not complaining), so I want to get this issue resolved quickly.
Now, I’m aware of the bypass door tension setting nut/bolt. I’m also aware that, as far as I have read, it is only accessible through the stove exhaust opening. I am painfully aware of how difficult it is to get this insert into the hearth and hooked up to my SS liner, due to the tight fit and lack of vertical play in the liner/my setup. So I only want to pull this thing if I absolutely have to.
The ‘gritty through the whole throw’ makes it seem like something else is at play, though. There’s definitely the possibility that a piece of flue cement has broken loose and made its way down to the bypass door gasket/frame and is interfering with how it’s closing (the mouth of the adjustable 90 ended up being a little out of round, so it left a bit of a gap between it and the exhaust collar when looking up through the fire chamber in the stove, so I filled that gap with flue cement using my finger). I’m going to try to inspect/vacuum that as best I can from inside the stove first thing. Then I’ll do the dollar bill test on the bypass gasket. I’m curious if you guys think it might be something else? I believe I can access some of the bypass handle/cable assembly by taking the right side panel off. Is there anything in there that I might need to check/adjust/lube? If I need to pull the stove, so be it, but I want to make sure I cover all other bases first.
Thanks in advance for any advice and suggestions!
