Moved to a new thread.
) as well as from some of the seams in the black stove pipe and the collar, which I had sealed well enough (I thought) with stove cement.
When I say this happening, I closed the thermostat completely, which should, theoretically, have cut off the air supply and put out the fire, but it doesn't do that. So the fire is still smoldering, getting enough oxygen from somewhere. The stove is practically brand new, and the door gasket is still very tight. The ash removal door in the bottom has never been opened.
I had tested the venting for negative pressure for several days before installing this stove. Sometimes there was no n.p., other times weak n.p. that was easily reversible using a hair dryer for half a minute, and it usually stayed moving in the right direction (up) for a while afterwards. When starting fires, even when I used only a little kindling, there has always been good draft, and I never had to use a hair dryer or torch to get a fire started and no smoke ever back drafted out the door before.
Today the weather is very different than when I normally burn. It's in the fifties today instead of thirties and below. Today for the first time smoke pours out the door when I open it, and it is coming out of all the other places I mentioned before. I put a heat lamp on the stove pipe where it goes into the wall thinking that might encourage some upward air movement. I also opened the stove amidst the smoke and aimed a hairdryer up the vent thinking that would get it started. It seemed to do that for a few minutes.
The stove has become warm after more than an hour of smoldering, which should be enough to reverse any weak negative pressure. But it hasn't. Another puzzle to solve with this stove! I doubt there could be a clog in the venting since I have only burned about one fifth of a cord of wood in this new stove, most of it tested adequately dry. The 8 inch rigid stainless pipe, insulated with vermiculite cement, was installed less than three months ago, and it has a cap and screen so no animals could have gotten in.
This BK seems to be very finicky.
I'm having a severe negative pressure problem with my new Blaze King 40 today, for the very first time. I've never seen anything like this happen with any stove or fireplace, in my experience. Smoke is pouring out of the bottom of the thermostat assembly box on the back of the stove and at the top where the thermostat control rod goes into the box (Years ago, the Blaze King people coached my incompetent dealer on taking those draw readings. Supposedly it came up as good enough. Not great but in a range considered acceptable for the Ashford. It works as long as the seal is 100% perfect. Except maybe when the weather is warmer and the wind starts to blow. Running exhaust fans at those times is not a good idea, as it tends to draw negative pressure into the home, as well sealed as modern homes are.
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
