bigbarf48
Had no idea that there is a species of hickory called "plain vanilla". From the charts I have looked at, locust, oak, and hickory are some of the higher BTU firewood.
Poplar, when green, is about as heavy as oak. However, poplar is mid level, if not lower, BTU wise and is a lot lighter than oak when both are seasoned. So, the entire heavy when green analysis isn't always true. Now, I will agree that the denser firewood has more BTU's in it. Thing is, when green a lot of the weight can be water. I bet you also understand the difference between weight and density. Kind of like when I was in grade school and I asked friends, which weighs more, 5 pounds of feathers or 5 pounds of steel. Some would actually argue with me that the steel is heavier. Trying to explain that 5 pounds is 5 pounds was frustrating, and trying to explain that weight and density are two different things was nearly impossible. Using weight as a determining factor in the field is not a good comparison unless both pieces are seasoned or they both have the same percentage moisture content. Lots of variables involved in how much a specific volume of wood weighs.
I use this link to attempt to figure out what a tree species is worth btu wise:
(broken link removed to http://www.chimneysweeponline.com/howood.htm)
The only two types of hickory on there are in the high btu group. Same goes for the myriad of oak and the locust.
My main problem comes from identifying tree species. Not quite as hard when they are still standing with leaves and dropping acorns, helicopters, etc. The best firewood looks like Osaage Orange/Hedge, but I don't even have a clue what it looks like in the field, much less in log form.
Much harder when they are dropped off in log form. I'll attach some pics of what we were processing.
There isn't anything called plain vanilla
And you said exactly what I was about to, green weight tells you exactly nothing about how a piece of wood might burn once seasoned properly. Pick up a piece of green sweetgum or cottonwood and then pick it up again when it's dry and you'll see what I mean
