I have an old Superior FC 3880 that doesn't do much except bleed heat and look okay. At present there is a kitbashed plexiglass panel in it keeping the cold air mostly out from the house. Obviously, there's no sealing it on burn days.
The opening is about 40.5" wide and about 32" high. The Superior firebox is 16 inches deep on the inside. It has an 8" stainless pipe chimney.
The outside of the chimney has a metal box protruding from it, so I'm guessing it could have a vent if I wanted to install one. The chimney sans box is covered in siding.
I want a high efficiency fireplace or insert of some kind that doesn't leak heat and doesn't need constant supervision like an open fireplace. My preference is that it doesn't break the bank if possible. This year I have already had a power outage and a dead furnace during subfreezing temps, so I'd prefer some supplemental and emergency heating that's more reliable than the open unit.
TIA
![Need to replace old Superior ZC Need to replace old Superior ZC](https://www.hearth.com/talk/data/attachments/250/250410-8704180898a4269f9e98db55f7e48f20.jpg)
TIA
