Need parts find dealer or interweb?
shtrdave
399
SW PA
I have a Harman P43 6 years old and now in need of a combustion fan, the dealer I bought it from is no longer in business. I think there is a dealer about 30 miles away and I know there is one about an hour drive.
So does one go find a dealer or order online some place?
Thanks
I look on line and order the best one I can at the best price point
In most cases on line ordering is cheaper than the dealer
Thanks
I would suggest buying a new fan blade as well. they also are available on line and not very expensive. The fan gets the heat from the fire and usually is stuck on to the point where the easiest way to replace the motor is to simply cut the motor drive shaft and replace with the new motor and fan .
Reactions: zinger827
I would suggest buying a new fan blade as well. they also are available on line and not very expensive. The fan gets the heat from the fire and usually is stuck on to the point where the easiest way to replace the motor is to simply cut the motor drive shaft and replace with the new motor and fan .Go on line or eBay because you can save dealer markup and sales tax plus you get the satisfaction of doing it yourself. A Harman is one of the simplest stoves out there and probably the most trouble free. I have seen many that are 12 years old and no problems other then normal cleaning.
Thank you, I ordered the one in the link, and I was planning on getting a new fan and they had them also. My fan comes off as I take it off at least once a year to clean.
Thank you for the help. link and advice. It is appreciated.
