Need help with repairs! Pacific Energy Super 27
Srzappia
9
NY, USA
We purchased a used Pacific Energy Super 27, said to be in great condition, “burns great but will eventually need a new baffle”. There looks to be more significant damage and I’m looking for guidance on whether or not we can safely repair/find replacement parts and if it’s worth the money to repair vs. trying to find another used stove in good condition. We are financially strapped, have both used wood burning stoves but never repaired one. This one looks to need a new baffle asap, railset, new bricks (we have 6 intact), baffle gasket? The crack on top seems to have been sealed but we don’t know the details. Thank you in advance!
  • [Hearth.com] Need help with repairs! Pacific Energy Super 27
It's been over fired, the white on top indicates that.
You've been swindled.
I would find another stove...
Reactions: Srzappia
Not worth fixing. Parts aren't cheap, and with a crack like that, it is scrap.
Buying used is a crapshoot. You have to closely inspect the stove for damage, but you still can't be sure that it hasn't been abused to some degree. Gonna be hard to find anything good, especially at this time of year.
I'd consider a "value" stove from Lowe's, HD etc. They are around $1K or under, depending on size. Drolet and Englander are well-regarded here. I saw Pleasant Hearth at Menards a couple days ago. It looked OK but I don't know if it's quite as good. You might go that route for now, and then start looking for a deal on a used stove of better quality, which will probably take a while to find.
Hmm, qualifies for the 30% federal tax credit..
That said, any modern stove, catalytic or secondary-burn like the Super, will require dry wood to produce decent heat. If you haven't got wood that's been split and stacked to dry in the wind for at least a couple summers, I wouldn't even attempt to burn wood this year. If you split and stack soft Maple or other lightweight wood now, it might get fairly dry by next fall.
Reactions: Srzappia
Eventually? That baffle was toast a long time ago. I'm sorry to see this, hope it was cheap. The crack on the top shows abuse, indicating there is a good chance the flame shield is shot or missing. It will need to be welded. The stove needs a full rehab. In addition to the trashed baffle, the firebricks are shot, the insulation side blankets need replacement. I'd do the door gasket at the same time.
Reactions: Srzappia
Many SBI stoves including Drolet models are offering the tax credit too.
Thanks so much
Ugh, yes this is what we thought. Thank you…
An exception would be that if you have a woodlot to work, you can find dead standing, or down but off the ground trees <8" in diameter. If most or all the bark has fallen off, it can be dry enough. You'll need a moisture meter to test room-temp wood, immediately after you split it open. Test in the center of the freshly-exposed face. Harbor Freight has moisture meters for $10 or so.
Do you already have a venting system in place? That can cost more than the stove.
I've blown through wads of cash getting myself set up to burn wood and 'save money.' 😆
  • Haha
Reactions: GG Woody
