Need help with Harman TL300 disassembly
paulnlee
419
Flemington, NJ
Been using the TL 300 for around 10 years, this one has the new style after burner. I have to replace the damper assy, it warped a bit to the front allowing the rod to fall past it jamming it. Got the top open and am now burning with damper open and regulating by the air slide. Can find no info on disassembly anywhere.
I guess I'm replying to myself. Damper open just doesn't do it. Too much heat. Have an offset needlenose plier that grips the nut on the damper and will do it manually, just need good gloves which can be had not at Lowe's but your local welding outfit
I really don't need a walk thru, replaced many parts on my earlier 300 including the damper assy. Just seems to me there's a better way than going thru the inners. Would like to take off the top but the damn nuts are on the inside. I think I'll be OK til May when I shut it down. Harmon cust. svc is lacking as are the dealers here and their 'TECHS" The dealer is contacting Harmon to see if any issues with warping. They will blame me for running hot. All wood very seasoned, been doing this for over 25 years, started with the 2BO but was too small.
Started disassembly today, only one frozen now busted bolt but it goes into damper assy so no big deal. Both lower bolts on both rear plates look frozen, have to come out to replace afterburner
Aren't those lower ones through bolted? On most versions they are. If that is the case just break them off and replace them.
But isn't the stove itself cracked? If so why are you bothering with working on the internals?
Yes they are. As far as the cracks go, they're 1/2" in each rear corner of top door so if Harmon does nothing I need heat. So far they're insisting it's up to the selling dealer to determine warranty and dealer is fighting with them. Harmon actually e-mailed me that they don't do warranty. Tomorrow I'm going to try and remove top door assy for easier access to damper. My parts list is growing and might be cheaper to buy new.
Again if the top is cracked why are you working on anything else?
They are not really an issue unless they expand. Top door seals them. Wish I could post pics
They will expand usually pretty quickly on a top. I wouldn't even count on another season out of it.
It may go like that for quite awhile but I wouldn't be putting any time or money into a stove in that condition.
I know exactly where the cracks are I have seen many of them on harmans that have been run with the bypass open to much.
Do you need help getting pictures on the website or do you need a camera?
One side, other the same
That doesn't look too bad. Got a friend with a welder?
Had some time today and finished disassembly. To replace everything will cost close to a grand. Some parts are still OK but since it's all apart might as well do it right. Now to decide replace or renew. Dropped a damn hinge pin, think I can find it? Noooooooooo
I hate when that happens. It may have rolled further away than thought. Try using a strong magnet all around the area to pick it up.
Again I wouldn't spend a grand on parts for a stove with a cracked top.
