I'm getting ready to hopefully put a drolet escape 1800i into my existing fireplace which appears to be some kind of old heatilator unit. I'm a bit confused with some of the information I've been pouring over. Is this a zero clearance? Can I fit this or another insert into this?
House is about 1800 sq feet with baseboard heat built in the 40's. I will get dimensions and a better/more pics when I get home. carpet is gone. back to hardwood that sits flush with tile in front. there are no blowers in it. the damper is a rectangular plate not like a butterfly but more of a lever type thing. looks like metal box needs to come out. I don't want to tear out any brick unless I have to inside for ss liner clearance. chimney is same brick with rectangular clay flue. could I just cut this whole box out and put the insert in. what if anything additional would be needed underneath the insert for insulation. Thanks in advance. sale on insert ends in 2 days.
![need help with drolet into old fireplace need help with drolet into old fireplace](https://www.hearth.com/talk/data/attachments/184/184715-b21c7de4ab3e29f854da59cf35b67af7.jpg)
