If choose to do this there is a very good chance you will blow the engine.nswoodstove said:what make is the engine?generally speaking its easier and cheaper to take it to a small engine shop because some engines may require special tools to get to the governor ,most times the culprit is a loose/broken spring,your could also remove the governor rod and gear up a manuel cable/rod etc,doing this modification makes the engine harder on fuel as it is running on high idle all the time, i would check out the cost of the governor repairs before going this route,
BrotherBart said:We need a terminology check here. You say "won't increase its idle". That speed contol on the engine should be in the "fast" position while you are splitting. No idle ought to be involved here.
The governor isn't going to do anything at idle. And when the wedge hits the wood that little pup is just going to burp and die if it is idling.
Jags said:BrotherBart said:We need a terminology check here. You say "won't increase its idle". That speed contol on the engine should be in the "fast" position while you are splitting. No idle ought to be involved here.
Mustang, I got a question on the log splitter that I think Bro B is getting at. Do you leave the splitter at an idle, expecting it to rev up when it feels a load (like splitting a log)? I ask this because... as Bro B said, these are manual throttle engines, they do not have a governor solenoid that will engage the "high" speed. You need to set the throttle at the operating rpm manually.
p.s. (BB - I hope I'm not putting words in your mouth)
