Hi Folks,
I've spent way too much time trying to find the right insert for our home - a 3 store 4100 sq ft propane guzzling ice cube. After we bought the house last November, we were pretty shocked by our propane bills being $600+ Dec-Mar and I've been looking at inserts ever since. After combing through every website from northerntool.com to efireplacestore.com to craigslist and back again...we though we'd found the perfect insert in the Osburn 2400...until we found that the back of our fireplace was 1.5" too small *sigh*. So...new friends at hearth.com...I seek your wisdom.
Here's what I'm looking for in order of importance:
1) Prefer an insert that can output 90-100k BTUs...but if our chimney can't accommodate such an insert, I've seen many that provide 70,000+ BTUs that will fit.
2) Budget of $3000 for self installation w/ fireplace liner
3) Qualifies for $300 EPA tax credit
4) Blower that can circulate at least 120 CFM and preferably has a quiet fan/motor
5) Easy load/ash cleanout (which I don't know much about)
6) Bay window preferred or large ceramic window will do if bay windows have some drawbacks
Fireplace Dimensions:
Front: 33.5" wide x 27.75" tall x 25" deep (straight to back)
Back: 27.5" wide x 27.5" deep (along wall)...narrows towards the top towards the flue
Flue: 27" x 11"...flue door looks to be 26.5" x 5.5"
The fireplace is all brick masonry.
I had a few questions:
1) I plan to use a 6" insert...with the flue door opening only being 5.5" wide, will I have to cut out the cast iron flue door frame or is there some type of adapter I could use or should I just bend the pipe through the opening?
2) We have 2 small (and curious) boys. We have a fireplace screen right now...would that provide sufficient protection to keep grabby hands from touching hot surfaces?
3) I've seen various chimney liners. While at efireplacestores.com, they offered a liner that was $550 which seemed pricey to me. eBay has various liners for less than 300 bucks that are the same specs (6" x 25'). There's even this one for less than $150 that looks similar to others:
http://www.ebay.com/itm/WESTAFLEX-9...964529?hash=item58e5873171:g:UDAAAOSwZJBX-8HS
Is this liner junk, or are others just overpriced?
4) What is the point of insulating the fireplace liner? Seems like a waste of money once the heat leaves the insert?
5) I have a huge supply of infested pines - loblolly pines overrun by pine bark beetles. I've read pine is the last thing you should burn and other people who say it's no big deal. I planned on burning the pine w/ a mix of other hardwoods. Is that ok, or should I just not burn pine at all?
6) Are there any fireplace insert features that are must have's that I've forgotten or that you'd highly recommend?
Thanks so much for your help with any advice and tips you can provide![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
