Hi there! I have been pouring over this wonderful forum and researching information on new epa woodstoves, going to dealerships and getting a mixed bag of recommendations. Hoping for some help from the good folks here on this forum!
I received a voucher from the state of MA ( worth $700 ) to replace my very old and loved 1897, ornate parlor stove. The new stove must be epa approved and have emissions at 3.5 or less. My stone hearth is an open concept area with 16' vaulted ceilings with 2 ceiling fans, a front door and two 4'x6' windows. This room is 22' x 15' and it is adjacent to the kitchen & dining area with approx. the same 22' x 15' area but with 8' ceilings. Upstairs has a loft and 2 bedrooms and a bath.
This past very long and coldwWinter, with my old parlor stove burning just about 24/7 and ceiling fans on med-high, while trying to conserve oil, I had to keep my oil heat thermostat on 60 to maintain a 60-62 degree indoor temp. The parlor stove can hold a tremendous amount of wood and puts out a lot of heat but the wood burns up fast. A load of 6 or 7 good sized splits would last about two hours down to hot coals. Thankfully, when I fully loaded at night I would have hot coals in the morning for easy start up. BUT, while trying to keep my furnace from constantly kicking in by burning constantly, I still went through 250 gallons of oil last winter and 5 cords of dry hardwood, mainly ash and maple. I am assuming a new modern stove would improve those numbers and keep me warmer.
So, I went looking at these new epa stoves and was blown away by the small fireboxes. Even the big stoves like the T6 seemed undersized but the folks at the dealerships taught me how these new stoves work but I am still a little skeptical. I don't want to have an undersized stove and I do not expect the new stove to heat the entire house considering my setup is not ideal. My goal is, with my oil thermostat set at 60, I would want the wood stove to push my indoor temp up to 65-70. My house is well insulated, built in 1990. Chimney is on the outside about 20' high. I have a very good draft, no issues with back drafting. Upstairs bedrooms & bathroom doors will be closed as I am not concerned about heating these areas. I am considering these following stoves. Lopi Cape Cod, Hearthstone Manchester, Alderlea T5 & T6, PE Neo 2.5, Jotul Oslo or Carrabasset. The T6 has an emission rating of 3.6 so not sure I could sneak that one by or not. And the Jotul Firelight emissions are 4.1 so that stove isn't in the running. I do like the height of the PE Neo 2.5 but the firebox may be undersized. Looks are important as the stove is on a large river rock hearth which is the focal point of the downstairs. One more question. Would wider ceiling fan paddles be better at pushing the hot air down than regular 6" fan paddles? I added a couple of photos of my interior set up. One looking down from the loft and the other looking at the stove from the dining room. Thanks in advance for any suggestions!
![Need help deciding on a new epa stove Need help deciding on a new epa stove](https://www.hearth.com/talk/data/attachments/134/134459-bc153fae6f804a11e4249c014be5ab73.jpg)
![Need help deciding on a new epa stove Need help deciding on a new epa stove](https://www.hearth.com/talk/data/attachments/134/134458-3bc0f43f5e0f7e865cdd0c907dbb129d.jpg)
