That's a clean-burning insert. Is the catalyst getting up to temperature?This is a Regency cat stove. https://www.regency-fire.com/en/Products/Wood/Wood-Inserts/CI2700
I use snap lock rods. Basically a professional version of the sooteater. But you don't have to pay for the pro version.sounds good. What kind of equipment do you have and does it work for inserts?
yes I believe so. I wait until I hit 500F to divert to the cat as per the instructions.That's a clean-burning insert. Is the catalyst getting up to temperature?
What does the cat temp do after you close the bypass?yes I believe so. I wait until I hit 500F to divert to the cat as per the instructions.
Hmm I am not sure what the cat temp is. I have the temp for the stove itself with the included digital thermometer but I wasn't aware I could measure the cat temp. Do these cat stoves measure that?What does the cat temp do after you close the bypass?
If it's installed properly that digital probe should be right behind the cat.Hmm I am not sure what the cat temp is. I have the temp for the stove itself with the included digital thermometer but I wasn't aware I could measure the cat temp. Do these cat stoves measure that?
ok I see so the temps I am reading must be the cat temp. When I close the bypass the temps go up. When I first got my stove I recall I could get temps up to 1300. then it kept going down from there over the past 3 years so I rarely got temps over 1000. Is there a possibility that the cat is clogged up from the creosote?If it's installed properly that digital probe should be right behind the cat.
The cat also may need replaced.ok I see so the temps I am reading must be the cat temp. When I close the bypass the temps go up. When I first got my stove I recall I could get temps up to 1300. then it kept going down from there over the past 3 years so I rarely got temps over 1000. Is there a possibility that the cat is clogged up from the creosote?
I am still not totally sold on cat stoves. do you have one? I am considering replacing this with a regular stove insert. seems like cat stoves are unnecessarily more complicated.The cat also may need replaced.
I am using one currently yes. They have their benefits but also some downsides. But honestly it doesn't sound like you are running or maintaining yours properlyI am still not totally sold on cat stoves. do you have one? I am considering replacing this with a regular stove insert. seems like cat stoves are unnecessarily more complicated.
yes I'll give it another 1 or 2 seasons and see how things play out and improve on my wood burning management. thanks.I am using one currently yes. They have their benefits but also some downsides. But honestly it doesn't sound like you are running or maintaining yours properly
Yes, I wait at least 2 yrs before burning it.I'm finding that my eucalyptus firewood really holds on to its water. While the other species I burn (mostly madrone and tan oak) can be dry enough to burn well after one summer the eucalyptus needs two. That's stacked in IBC totes which are uncovered and in the sun for the summer. Under cover all year it might need three.
I think the temps went down over the years because of the creosote buildup. But yeah it doesn't hurt to have another one so that's a great idea. Might be a good experiment to see how it changes the temps. I'll definitely be doing a better job monitoring the moisture content and also doing a better job of storing the wood. I have tarps on the wood and we've had some really heavy rains this winter that caused a lot of the wood to get wet so I'll definitely do a better job on keeping them dry now that I see what's at stake here.If your cat temp goes down, and you have had this stove for three years or more, and you burn e.g. every night for 5 months, I think your cat simply is at the end of its life. They are good for about 10,000-12,000 hrs.
If you are into wood burning for the long haul, then build a well-ventilated woodshed to store the wood. It solves a myriad of problems. There are many examples in the Wood Shed forum here.I think the temps went down over the years because of the creosote buildup. But yeah it doesn't hurt to have another one so that's a great idea. Might be a good experiment to see how it changes the temps. I'll definitely be doing a better job monitoring the moisture content and also doing a better job of storing the wood. I have tarps on the wood and we've had some really heavy rains this winter that caused a lot of the wood to get wet so I'll definitely do a better job on keeping them dry now that I see what's at stake here.
Good news, if you're able to access the flue by just opening the bypass. I scrolled thru the manual, but didn't see any side cross-section view that made it real obvious if this is the case.This is a Regency cat stove. https://www.regency-fire.com/en/Products/Wood/Wood-Inserts/CI2700
There's a few things going on here. A properly-functioning catalyst will maintain clean reburn at any cat probe temperature over 500F. Note this temperature is measured at the back of the combustor, via your combustor probe thermometer, the actual stove exhaust temperature may be closer to 250F under this condition.ok I see so the temps I am reading must be the cat temp. When I close the bypass the temps go up. When I first got my stove I recall I could get temps up to 1300. then it kept going down from there over the past 3 years so I rarely got temps over 1000. Is there a possibility that the cat is clogged up from the creosote?
Not unnecessarily, at all. There are non-cat stoves, which perform this reburn function without the aid of a catalyst, but they must maintain reburn temperatures over 1100F. By comparison to the cat stove, this severely limits the useable temperature range of the stove. The sole purpose of the catalyst is to allow you to maintain that same clean reburn down to 500F, which enables the user to turn the stove way lower, and get burn times at least 2x-3x longer. This may not be important to everyone, but I wouldn't use the word "unnecessarily", and I don't really think they're more complicated.I am still not totally sold on cat stoves. do you have one? I am considering replacing this with a regular stove insert. seems like cat stoves are unnecessarily more complicated.
I just looked up Top Down fire. I guess I've been doing a Down-Top fire this whole time. I'll try the top down approach. Thanks!Well good job getting up there and finding that nasty chunk. Try starting fires with top down set up to reduce your smoke and creosote. Also dry wood as others have stated. You should go from 10 gallons to a few cups if you do this.
The rest of the post is good advice, but this is total nonsense, as many thousands heating their homes with a non-cat know.Not unnecessarily, at all. There are non-cat stoves, which perform this reburn function without the aid of a catalyst, but they must maintain reburn temperatures over 1100F. By comparison to the cat stove, this severely limits the useable temperature range of the stove.
This thread may be helpful.I just looked up Top Down fire. I guess I've been doing a Down-Top fire this whole time. I'll try the top down approach. Thanks!
