I am having major problems with airflow in my wood stove with tons of smoke pouring into my room. I cleaned out my 6" liner with a Wohler viper and about two 5 gallon buckets of creosote came out so I was quite happy. However this didn't solve the problem so now I am suspecting it's the chimney cap that's completely clogged. I'm in California where they have the more restrictive chimney cap/spark arrestors with smaller holes. The problem I have is that this chimney is super tall and on a very steep roof so it will be quite dangerous to try to climb up there. The guy in the picture must be about 35-40 feet up there. I had to have a lift to install the liner 3 years ago (as shown in this pic). These lifts can be quite expensive to rent so I was thinking how I might be able to clean the chimney cap without spending a lot of money (this would be every year)? I can walk on the roof with a safety harness and I thought about banging on the chimney cap with a long pole but not sure if banging on the cap will be enough to knock the creosote loose? What about spraying it with hot water? Not sure I like the idea of water running down the liner. If I do go the route of renting a lift how much risk is there to going up and doing this myself? Or should I just bite the bullet and pay $1000+ to hire a pro to do this?
![need help cleaning super tall chimney need help cleaning super tall chimney](https://www.hearth.com/talk/data/attachments/292/292438-af38cb4eaa2a551834902031d50be984.jpg)
