As this winter drags on, I think about golf in California , where my buddies are. I was thinking about a propane boiler for backup just to keep the place from freezing for a couple weeks. Anyone have a recommendation?
The garn has ports for nine 3500 watt elements,I don't have enough power in the boiler building to run one 3500 watt nevermind 31,500 watts. Our electricity rate is fairly low , I still think this would cost about $75.00 a day to run plus the cost of installing a 100amp service in the garn barn. I found a slightly used Burnham series 2 lp boiler on CL for $750 .IF I add this to the system and set the thermostat to about 60 I think it would cost less than the $75 to run,I thought the garn had an electric coil in it to keep the water from freezing for back up?
I am mildly satisfied with the garn ,lots of wood , when they say one fire a day it might last for 6hrs on a cold day.I was looking at the Garn pac on youtube. I thought it was cool. but yes it has a seperate service not sure of amps. I thought it would be ideal for a automatic propane generator for power outages.
Have you been satisfied with your Garn?
Ward, I have propane boiler back-up in the house and in the shop. The one in the shop is a wall mounted that I was given by a friend years ago. The one in the house will keep my lines from freezing as I have a timer that runs the pumps in the Garn boiler room intermittently to circulate through the HX.I am mildly satisfied with the garn ,lots of wood , when they say one fire a day it might last for 6hrs on a cold day.
Reload the fire every 2hrs or 3times.You mean you have to burn every 6 hours?
Or one fire lasts 6 hours before it burns out but you only have to burn once a day? (or something like that).
Hi george, how much propane would you use just to prevent freezing? I only have an 80gal tank that I use for the kitchen range and outdoor bbq. I'm sure the propane co would lease me a larger one if needed.Ward, I have propane boiler back-up in the house and in the shop. The one in the shop is a wall mounted that I was given by a friend years ago. The one in the house will keep my lines from freezing as I have a timer that runs the pumps in the Garn boiler room intermittently to circulate through the HX.
I am firing twice a day with the temps hovering presently at -7F. You can only get so many BTU out of a pound of wood and unfortunately my house and shop use more BTUs when it gets colder. I also am not letting the boiler go down to 110*F.
Keep warm.....think about golf.![]()
I think that would work, or you could put one element into the port. I need something to prevent the house from freezing as well as the Garn.Ward, I only had to run mine once to prevent freezing and at the time i was also running the house at 55*. I would have no way of telling how much fuel was used to just heat the water to the Garn when the pumps were circulating.
If my goal was to keep the Garn and the supply/return lines from freezing I think I would try a small electric heater placed inside the woodbox of the Garn. I would close off the air supply and the exhaust. I cannot see anything freezing with the pumps circulating intermittently as well as I have insulated the Garn and the underground lines. Even a small electric heater should do the job. Of course this strategy is for freeze protection only.
What do you think?
