Need advice on covering wood for the winter with a tarp that's too big
MissMac
923
NW Ontario
Morning fellas. We've got some heavy rains coming (finally), and it's time for me to protect all the epic drying I've been able to accomplish with my firewood this summer. It has been a bone-dry, drought summer here. This big ole pile of ash will be moving into my wood shed next summer, where it will sit for another 2 years before it goes in my stove. It has been uncovered all summer, and is really coming along. I want to cover it up for the winter, so that I don't have to wait 2 months for it to reappear from under the snow next spring.
I'm covering it now, since we're getting into what is traditionally a wetter and cooler time of year here, and because i want to put it away dry as opposed to soaking wet (which it will be if I don't get it covered this morning). As you can see from my pics, the tarp hangs down to the ground on both sides, leaving only airflow on the ends of the piles (oriented N-S). It was the closest fitting tarp i could get for my pile without having to fart around with multiple tarps. There will be a couple feet exposed on the south end, but that's okay.
[Hearth.com] Need advice on covering wood for the winter with a tarp that's too big[Hearth.com] Need advice on covering wood for the winter with a tarp that's too big[Hearth.com] Need advice on covering wood for the winter with a tarp that's too big
For the purposes of this weekend, I'm just going to tie it down as-is to keep it dry. However, I am concerned that if I leave it like this all fall/winter, I could get some moisture build-up under the tarp which is obviously no good. So, I'm looking for advice, as I've never covered a pile like this over winter before. I know that ideally it's best just to top-cover, and leave the sides open (and maybe jimmy it so that the rain isn't dripping down onto the sides off the tarp). But, the easiest solution is for me to just tie it up as is and leave it. I could try to fold the tarp to create just a top cover, but then i will have to weigh it down on top of the pile (cause I'll loose the grommets), which will be a hassle, and also will make it so that I won't be able to have things as taught to keep the snow/rain sliding off. So, if this was your pile and your tarp, how would you approach it for over-wintering?
Thanks!
I use ground anchors for my tarps. It pulls the sides away from the wood and allows the rain to run off. One can take multiple tie ropes. I keep my wood on racks so I get airflow underneath. This year I am going to set a couple of metal fence posts in five gallon buckets of concrete with the metal caps on them. I am trying to create a tent that keeps the tarp with minimal wood contact.
[Hearth.com] Need advice on covering wood for the winter with a tarp that's too big [Hearth.com] Need advice on covering wood for the winter with a tarp that's too big
Reactions: MissMac
You will not build up moisture if you leave the ends open like that in the picture. When the air moves through it at will keep it dry. As for the tarp being big thats ok. I do the same thing. I put rebar in the ground and attach the tarp to it via bungee cords keeping the tarp out on a slight angle.. Your wood and stacking is looking pretty nice I have to admit.. You should be proud..
Reactions: MissMac
i would fold it up if it were mine. the sun rips up the tarps or plastic in about a year so i make the plastic or tarps come down half way from the top and fold in the ends and use sheetrock screws with fender washers never ever fails. i've had the wind strong enough to blow over the wood pile but the tarp or plastic is still attached
Reactions: mrd1995
View attachment 281117 View attachment 281118
I was actually going to pound a few t-posts into the ground and run a rope between them to create a ridgeline for the tarp, like you're thinking of, but I couldn't find t-posts anywhere in town.
Thanks!
I think I saw someone on here post a youtube video of a guy who screwed his tarps into the wood pile. Looked like an interesting approach. We had some severe thunderstorms and wind here yesterday - even got into a tornado warning for about 40 minutes, and my tarps all held up. :)
Reactions: fbelec
That's a interesting thought screwing the tarps into the wood pile---could you make wooden stacks if you cannot find t-posts--just thoughts here but I think screwing it into the wood is interesting.. clancey
more work than it's worth, and i'm not supposed to use any sort of power tool that has torque (cause of my shoulder/bicep).
I would fold and nail or screw the tarps to the splits. With a bit of overhang. Place some stones/pallets or what ever on top. Dont forget, tarps are not water proof. Water will pool and eventually drip on the splits below the pooled water. No big deal the surface water dries fast. Some of my stacks are tarpped (2019) and I have not touched or readjust them once. I will try to find a pic
Reactions: MissMac
not a good pic but you get my point. Seethe green/blue tarp
Reactions: MissMac
I either stack a row in the middle or make a few sapling poles to run down the middle for ridge. This year I saved my old gutters just for this purpose. I feel like a few criss cross splits then anchor rope low then run up and over the splits to the other end would work.
Reactions: MissMac
I like to fold the tarp to desired size and run straps over the top to keep the tarp from unfolding. That's how I deal with storing round hay bales since I don't have a barn.
Reactions: MissMac
Yes!! Thanks for the great idea. I just might try this!
Reactions: EbS-P
i screw mine have way down the stack about 2 feet on each side then when i need it i get my battery drill and unscrew what i need then when my garage is full i screww back down the plastic for the next time i need some. and i never have any left over screws in the ash
Reactions: MissMac
i haven't changed anything so far with the initial tarp set up, but i have been contemplating folding the tarp in half long ways, and then running a bunch of old fence posts through the folded side to hold weight over there, and then tie off all the grommets on the other side (so that it's more of just a top cover). I just keep flip-flopping between what is best to keep the snow out and have the pile snow free as soon as possible in the spring. I think that if I just go top-cover, then the snow will penetrate the stack more where as if i leave it all draped, i can just pull the tarp off in a kind of ta-da fashion next spring and start chucking that wood into the wood shed.
I used to put some large pieces of wood on the top of the tarp. And lean pallets up against the side to hold the tarp in place.
i used to do the pallet thing also but the wind still took my tarp. nothing like fender washers and a screw
I first lay down tar paper like the stuff they put on the decking under a roof. Then, on top of that, lay down some old roofing tin, removed from an outbuilding when a new roof was installed. The pallets go on top of that. By insulating them from the bare ground, the pallets will last a couple of seasons, rather than just one when they are placed on bare ground.
Roofing nails, the ones used to nail down asphalt shingles, work well for affixing the edges of the tarp to the wood. Amazon.com carries 4' X 20' heavy duty tarps for about $20 each, which is about right for my wood piles. I have a pile of old bricks out back, and lay a few of those on top of the stack to help hold down the tarp in the wind.
