Need a small pellet stove for bedroom
Galroc said:
I asked my local dealer and he said as long as it has an outside air kit installed.
But, I would still ask the building inspector.
An OAK being installed isn't going to help if there are loose seals and the combustion motor does a paws up routine on you and there is little to no natural draft in the flue or the flue becomes chocked. Not to mention if the stove doesn't have a sealed hopper and the paws up routine takes place.
Even if the inspector signs off on it and I doubt if that'll happen, I wouldn't do it. I want that stove in another room with several warning devices between it an me when I sleep. Being a bear I'd stumble into a stove still groggy if the alarms went off and the stove was in my bedroom.
Good points..which is why there isn't a pellet stove in my bedroom..,
Instead, I spent $1000 and added more insulation to my attic.
Now that is a smart investment! Payback for the life of your home and green too, as less fuel of all types are consumed, and also warmer bedrooms.
in most states-towns its against building codes-and its in most manuals if not all. I never would put one in a bedroom. if you need heat- we put electric mattress pads on- cost $60 and well worth it- monthly operating cost of $3.00. A real good heater is the "Edenpure Infared heater",low operating costs-around $35 a month using it 8 hrs a day. The cabinet doesnt even get hot.We're pretty sure we'll be getting one of those also.
On page 6 of my Harman manual it reads DO NOT INSTALL IN SLEEPING ROOM
I`m going to go out on a limb here and assume they mean bedroom.
folks , i spoke today with a fellow who had CO poisoning from sleeping in a room with a furnace (wood add on) seems he was living in the basement of his mom-in law's where an old oil furnace and the add on wood unit were co-located, chimney install was a cobb job,(unpermitted, uninspected install) done before his arrival, noone else in the house was affected. seems like the stove would burn ok once he got the flue heated up, my theory is that the flue was cooling in the coal stage and the unit was backpuffing when the oil furnace kicked on to take over from the dying wood fire in the wee hours of the morning. CO detector (at least a decade old) never went off. flue is a prefab exterior unchased triplewall at 32 ft from basement. single wall stove connector pipe and a TEE which was outside but not class A. uninsulated, then the triplewall up the side of the house. guy was lucky to be able to talk to me today. we identified his issues but i seriously believe he will not be using the stove anymore as long as he is sleeping in that room. the unit was fine , flue was biggest problem. CO detector was way outdated, and the oil furnace was pulling from the basement as well so you have competing flues. guy is SERIOUSLY lucky not to be getting prepped for a long dirt nap.
several lessons to be learned
1. NEVER install a combustion heating device in a sleeping room, it may be safe when working properly but any machine can break , and that one time could spell disaster!
2. CO detectors/smoke detectors, a MUST HAVE and need to be replaced on schedule. most will only have a usable lifespan of no more than 5 years. and as stated in other posts in this forum , the "test" button only tests the alarm , it does not test the detector!
3. NEVER assume an install is done correctly unless you were there , and are certain it was properly done and inspected! always have a wett or similarly certified chimney professional inspect any flue system prior to putting it into use. any new install into an existing flue system requires a class 2 inspection to be done prior to install, and i strongly recommend the same with anyone moving into a home with an existing system or flue that you intend to use.
folks, we dont put these warnings in manuals to make it hard on the public, these warnings are there in the hopes that they be adhered to for your SAFETY, people die from CO poisoning every year, from a multitude of products , and for a multitude of reasons. CO scares the bajeebers (for lack of a stronger term that i can put in print) outta me. my phone call this morning had me shook up pretty good even though i was actually talking to the "victim" and not someone else who was wondering why someone died in their house. speaking for the industry as a whole;bottom line PLEASE PLEASE! be safe , follow our instructions , heed our warnings, have your installs inspected , install and maintain the proper sensing devices, and operate our products in the manner they were designed to be used. you are inviting FIRE into your home, you have to respect that to be safe coexisting with it.
sorry for the rant , but safety is my buisness and unsafe things scare me.
Pete,
please, please, please....do not put a pellet stove or even a gas heater for that matter in your bedroom!i have friends who had put a gas heater upstairs in the bedroom thier sons slept in....they dont have sons anymore due to a gas leak.there are sooooo many other ways to warm your bedroom up, try the edenpure heater. the reviews i have heard on these are great. another friend bought the larger one for his bedroom as there was no heat at all , and he loves it.you will be just as far ahead if not farther,the larger model is hundreds of dollars cheaper than the smallest of pellet stoves, and the heat is adjustable.
if you are going to spend the money, tyr the edenpure, worst come to worst, you could always sell it and recoup some of the money to try something else.we use a small ceramic heater with a stat built in and it heats my bedroom to the point that i kick covers off in the night.
mike
One quick note. Last month my pellet stove malfunctioned. Making a long story short, the stove was located in my family room downstairs. My one son was sleeping there. My other son smelled smoke from upstairs and went down and saw the entire room was full of smoke from about 6 inches down from the ceiling. He woke his brother up and called me to come. I opened the stove and removed the burn pot from the stove and thrue it outside and then opened the windows. Lesson learned. Oh and the fire detector malfunctioned. Never went off.
Remember on PBS years ago they had the yule log on TV during the holiday's. Turn up your electric space heater and enjoy the fire safely.
Portable electric heaters are quite dangerous. Just take a look at 14 gauge wire that is used on them.
http://www.toad.net/~jsmeenen/electric.html
Installing some electric baseboard is the way to go for heating 200 square feet. It is easy to do.
http://www.wikihow.com/Install-Baseboard-Heating-(Electric)
I have found it is cheaper to use electric baseboard to heat my 672 square feet rather than running my pellet stove.
The reason it is cheaper to heat my space with electric is partially due to the fact that the pellet stove cycles frequently (it is a QuadraFire Sante Fe). Every time the stove gets a call for heat it burns up pellets coming up to the temperature needed for the convection blower to kick on. That time frame is ten minutes.
That ten minutes is wasted btus. Add those lost btus up over the course of a day and the efficiency of the stove has dropped down to around 30 percent and electric heat has become very affordable.
Using electric baseboard is 100% efficient and small spaces can be heated using only the btus actually needed. More than likely the btus a pellet stove looses up the chimney during start up and operation
would more than heat any area under a 1000 sf.
Over the last few day's it has taken 55kw a day to equal the Sante Fe using a bag and a half of pellet per day. At .16 per kw that is $8.80 per day and the pellet stove would be $8.97 plus the cost of the electricty to run the stove.
If your going to use a space heater at least unplug it when it is not being used. I had a fire last year from a space heater that was just plugged in. Was not pretty.
you can get a nice electric fireplace and mantle for under a thousand dollars and they will heat 250 sq ft at 5000 btus if u instal a 220 plug u can get 9500 btus of heat
Invest about $60 on a nice oil filled electric radiator and you'll be very happy !!
