Need a new add on furnace
Husky546
2
Minnesota
Hey guys I’m looking for a new add on wood furnace. I currently have an old Johnson energy system wood burner that I’m sick of fighting with. It’s at least 25 years old, falling apart and honestly probably not safe to use anymore.
I’m in the market for another add on style but I’m not finding much I like (at least not at the big box stores) House I’m heating is 2000 square feet split evenly between a basement and the main floor.
In a perfect world I’d like something that has a damper that’s controlled by a thermostat and not the old spring style and a secondary burn chamber would be great.
Anyone have any suggestions? Not interested in anything shelter makes
I suggest you read a bunch to help you figure out what you want.
Stoves and regulations have changed in 25 years, make sure you can install a new furnace without a bunch of other work, like a flue upgrade or additional flue install.
Good on that end just upgraded the flue two years ago to a stainless liner and got the blessing from my local code official. He was the one who first suggested I upgrade the furnace itself.
Look into a Kuuma Vapor Fire 100...........best out there.
(broken link removed)
Wise choice...avoid the current stuff from Firechief too, exact same junk as Shelter, just a different color.
There's no longer anything available in a big box store that you want to own...you pretty much have a choice between the Drolet Heat Commander, and a Kuuma VF100.
One of those is made to last 5-10 years, the other will outlast you...and is stupid simple to operate too!
There’s only two choices. Drolet or kuuma. Both are automated as you desire and both have secondary burn so they are efficient and clean. One costs a lot more and has no window.
Over simplified it just a bit. ;lol There's only one person on here (that I know of) who has had the opportunity to use both of these furnaces back to back in the same heating season. You can see which one he chose to use.
Reactions: woodey and Highbeam
