I also considered it a place to save some money. If you are going to sell through a box store, you have to cut costs somewhere. A slab of quality stainless may cost half of what they wholesale the stove at.
Indeed it did. If I got the ashford 30.2, it's pretty huge stove, would i (on an average winter day) get to watch the fire burning in the stove, or would it be pretty hot for the small house we're in to run it that highThis kind of drifted away from the stove selection. With the size of the house; the Ashford can be adjusted down with a full load of wood and not over heat you while getting long burns. Buy a spare CAT or 2, gaskets and adhesive and call it good.
Unless your house is poorly insulated allowing you to run the Ashford higher, probably not. If you want overnight burns (or longer) you will face a tradeoff; sitting in your skivvies watching the flames or engaging the cat throttling back your damper without having to strip down; on the colder times you can get more ambiance from the flames.
unless you don’t have a CAT stove which is the decision the OP is making.The cat should always be engaged (i.e. the bypass should always be used once the cat is up to temperature).
It’s not just box store stoves, even the most premium brands use the stupid fragile boards.I also considered it a place to save some money. If you are going to sell through a box store, you have to cut costs somewhere. A slab of quality stainless may cost half of what they wholesale the stove at.
I'd say the main room is around half the house. 500It's hard to say. If the house is moderately insulated then once temps dropped into the -10C you may be able to open it up for medium burn and some fire show, though it sounds like the actual open area to the stove is much less than 1000 sq ft, is that correct? How large is the open area not including the small closed off rooms?
Good points! A little insurance for these over drafting incidents would be a pipe damper or dare I say it, a slight mod of the air intake.
When my dad was driving the family station wagon to a remote campground way out in the sticks, down some little county road, he'd say "This road looks like it will go up a tree and into a knothole pretty soon."EPA’S greatest concern. And they follow these threads.....
OK, I was thinking 600 sq ft. This is a small area to heat. The side rooms will get some heat, but not nearly as much. This small of an area is a challenge to heat 24/7 with wood so caveat emptor. I understand it can get very cold there, but what is the temp for 85% of the winter? That is what will determine the best stove size, not the extreme weather events. A BK stove running on low may work out best as long as a great fire view is not a priority for all of the time.I'd say the main room is around half the house. 500
Not most really. Hearthstone and quad use them. Regency lopi PE and several others dontIt’s not just box store stoves, even the most premium brands use the stupid fragile boards.
I may pm you asking how to do this if it ever comes down to it hahaWhen my dad was driving the family station wagon to a remote campground way out in the sticks, down some little county road, he'd say "This road looks like it will go up a tree and into a knothole pretty soon."Well, that's where Todd and I live..far off the beaten path, far from the madding crowds..and the authorities. It's beyond jurisdiction. Same holds true for Hermit. No one goes up there, with the threat of hypothermic death ceaselessly stalking you.
The only law out here in the hinterlands is frontier justice. But if the feds ever do come after us, we just take the restrictions off the air, let the stove run, and melt the evidence.
Leads one to wonder if we have any moles on the forum, reporting back. Let's see...who here has the closest relationship with the wood heat powers that be....Ohhhh, myyyyyy!!![]()
SHTF..Sheriffs Halt The Fires.![]()
I'd say average winter is -5 to -20 for most of the winter. Extreme weather events get to like - 35 or so, more with windchill. Milder days hover around 0OK, I was thinking 600 sq ft. This is a small area to heat. The side rooms will get some heat, but not nearly as much. This small of an area is a challenge to heat 24/7 with wood so caveat emptor. I understand it can get very cold there, but what is the temp for 85% of the winter? That is what will determine the best stove size, not the extreme weather events. A BK stove running on low may work out best as long as a great fire view is not a priority for all of the time.
You’re worried about solar flares wiping out the electronic infrastructure of civilization and you keep your savings in crypto? How will you pay your neighbor for grain when your phone dies and all the networks are dead?All great discussion here guys, I would love to get a Woodstock, but I don't know if I'm able to up here in Canada. If someone wants to work out a deal and deliver it to me from the states, I'll pay you personally in the CryptoCurrency of your choice. Does Woodstock have a huge backlog right now?
Got it. Cold temps, but heating a small space. That's a challenge, Stick with the Blaze King. It's sold in CA and will run on low when needed.I'd say average winter is -5 to -20 for most of the winter. Extreme weather events get to like - 35 or so, more with windchill. Milder days hover around 0
Edit: all degrees are in Celsius.
Is my vote. No cat = less maintenance. Firebrick interior easy to make off grid repairs possible. Goodalderlea t5
Two great stoves. If SHTF you can burn furniture in the noncat but a cat can be poisoned if you burn garbage.Is my vote. No cat = less maintenance. Firebrick interior easy to make off grid repairs possible. Good
fire show. Stainless baffle could be fixed or repaired
Steel jacket evens heat out. Looks good. Swing out trivets aid cooking. If it’s too hot build smaller fire or use use lower BTU wood. It’s it to much stove? Absolutely. So is the F500. BK is the only sure thing for the right size that won’t roast you out. Decision time.
Cat or no cat? BK if you want the cat. T5 if you don’t.
To simplify; buy a secondary non-cat stove with a large enough fire box for an 8-10hr burn, you will have a beautify fire view of the secondary burn but will sweat your crackers off for 3-4 hours then it will level off; or go with the Ashford, 20 minutes after engaging the cat you can turn the damper setting down and level off the heat output on low (for the next 25- 30 hours) while only seeing a glow rather than a flame. Life is full of shade offs.Btw I just wanna thank everyone for helping me out here and participating in the discussion. I'm really starting to get fed up with the hard decision and feel like I'm just going to impulse choose something just to get this over with haha
