Hi, I've got a cubic mini wood stove, and I'm in need of some advice on installing it in a sprinter van. Most people will say ah, you can't do that, but that's what I'm gonna do, with all appropriate safety measures and proper installation.
So I need some 3" double wall stove pipe, and I've realized this is very hard to find. I found some on their website (http://cubicminiwoodstoves.com/coll...4-ss-24-stainless-steel-double-wall-flue-pipe), stainless double walled, 22.5" usable length /$43, and I'm hoping I can find a better deal than that. Anyway, if you know of a place to find this stuff that'd be great. Or should I just go for single wall, like in this picture?
The plan: Stove located behind drivers seat & metal cab partition. Tile and fireboard under the stove, bolted to the floor. CO detectors on floor and ceiling. Stainless sheet along the walls, with fireboard and .5" airgap between fireboard and SS. 3" clearance from stove to wall. Double walled stove pipe makes a straight shot 5 feet up, out the roof. A 5" diameter hole is cut in the roof, a silicone chimney jack is installed with 2" of clearance between chimney OD and van roof, and then an H style chimney cap. (I figure an H cap is my best bet at dealing with heavy rain and highway speed winds, with least aerodynamic drag. Any better designs out there for this?).
Edit: Will this pellet pipe work? http://www.homedepot.com/p/DuraVent...ble-Wall-Chimney-Stove-Pipe-3PVL-60/100679684
![Need 3" double wall pipe, and advice, for cubic mini wood stove in sprinter van Need 3" double wall pipe, and advice, for cubic mini wood stove in sprinter van](https://www.hearth.com/talk/data/attachments/187/187202-10b2cdff8e95358fe57a9eda7486a571.jpg)
