Hey All,
First season burning a Napoleon 1900, and noticed something the other night that got me wondering. The other night, I had filled the firebox pretty good for an overnight burn, (on a bed of good coals), and let it go on high a little longer than usual (maybe 25 minutes?). The stove is in our basement, and when I went down to adjust the draft, the stovepipe thermometer was around 500F. Still in the "safe" range on the thermometer, but pushing it as far as the Nap. specs go. For some reason, I decided to turn the lights out and see if anything was glowing. We have a cast iron kettle on the built-in trivet, and under the trivet, I could see that the top of the stove was glowing faintly. I quickly closed the draft reg. down and the temp. started dropping.
Tonight I had the same thing. Had a good bed of coals, added a load of wood, and let it go for about 20 minutes before checking it. Pipe therm. read 475, and had the faint glow under the trivet again. I checked the stove-top temp above the door, in fromt of the louvres, and got a temp reading of about 650.
Both times I noticed that the flames coming out of the secondary tube were really roaring and yellow.
This stove seems really touchy. When I close the draft reg down, the temp drops to about 200-250 on the pipe after half an hour.
Seems like it reaches peak temp very quickly, and if you're not careful it burns through a load of wood really fast. I'm burning mostly oak and cherry, well-seasoned.
I've also noticed that I'm getting some draft at the ash cleanout door. It's closed correctly, but the coals always burn very bright over it, and burn down to ash very quickly over it. That space is always burned down quickly. I don't see any air blowing through and causing extra flame, but it does seem like some air is getting pulled through.
Any other Napoleon users out there noticed these things? Is the glowing an issue? Do I just need to be extra vigilant with my draft control?
