The last two days have not been to cold here in new jersey so I tried something a little different with the progress. After I established a small coal bed from a cold start I loaded about four to five splits in the stove with the damper about 60% closed, after the wood begins to char up a bit and my stove top temp is over 250 or my flue is 300 I engaged the cat and wait about 5 minutes or so then I close the damper all the way and open it up just about a quarter inch or so. What I have found out is with the stove not that hot,when I close the damper down you see the flames just lift off the logs and the secondaries just kick in for a short time,then the stove will sometimes go just black with that occasionally flame going up and you see that nice light show from the gases burning, then eventually you start to see the flames coming off the bottom of the wood and going up the fire box with out those secondaries really kicking in, that lasts for for a good amount of time before you just see the stove just settle down with that red glow from the bottom of the wood and then begins the long slow burn. My temperature during this peak time reached about 475 with about four to five splits and just cruzed at about 400 to 425 for a long time before I went to bed. What I came to conclude is I think you can’t get that fire box cranking with that damper open for a long time before you engage that cat because if you do the secondaries will go like crazy for a long time ( about 3 plus hours) and the stove will throw out a ton of heat from the glass and will roast people out with a small to medium house, with the way I just explained the stove did get to about 475 but i did not feel that strong heat from the glass like you do when the secondaries are going strong. So yes I think you can get that uniform steady heat from this stove, I will try this method and report back if you all like, I don’t need much heat right now with temperature in the forties and tomorrow in the fifties..
I’m liking this stove more and more every day
Sorry if I went on to long I’m just trying to explain myself the best I can, hope this will help other folks with the Progress.
ciccio
ciccio
