After way too many way too late nights in a row in the basement, I'm taking this one off - so time for an update.
This has been a heavily fueled project:
New boiler got wheeled into place, after fixing my backwards ash pan issue:
There are gaps in this, once again I didn't stop to take many pictures. So jumping ahead a bit, a few pictures of things half done as they stand now. Boiler front all plumbed up:
I put two tridicators in the boiler outlet & inlet. Just because, mainly. Also tranferred the fresh supply components from the old boiler. Closer here - but a dark pic:
Stepping back a bit, there's the stack exit, new dump zone above and existing supply line above that, new hot water tank, electric boiler, aquastat & sidearm in background, and monometer upper right:
Stepping around the back a bit to the other side (tight busy space back there), looking down is the return line. Zones on left, sidearm next, then connections to storage thru wye to boiler:
Stepping further, looking up at top piping. Existing return manifold at top, diagonaling down to retun at bottom, supply header with aquastat, top of electric boiler & its circulator. Some of that looks confusing with parts blocked by piping:
Then just to the left, above & behind the electric boiler, is the sidearm. One of few things I have any insulation on so far:
I used 1" pipe for supply & return on that, as that is what the sidearm fittings were. But I should have reduced it - I think too much my flow goes through that when the load circ is on. For now I've got the ball valve partly closed. I'll be adding more controls to that circuit eventually, the zone valve isn't wired up. Right now it's just heating the hot water tank by convection when hot water isn't being used. And I had to partly close the valve on the domestic through line, because with it open all the way the water was short circuiting through the sidearm to the tap when hot water was being used & not getting hot enough.
Here's another shot of the expansion tank all hooked up after some expansion action:
Have to thank whoever it was here that tried the fishing float thing. Not sure how long it will last, but I like it. I also have discovered another issue here. The load circ is just the other side of the wall, and when it first starts, it seems to do most of it's pulling from the tube. The float drops like a rock out of sight. I might have pulled a little air once before I noticed what was going on. I will pull apart the top of the tube & choke that down from 3/4 to something real small to try to stop that from happening.
On the expansion topic, I hooked up my old one to the top of the boiler, same as it was before - since it was right there anyway. I added enough parts to give another sight guage, a pressure guage for it, and a way to add air:
(Not a good pic).
Here's the flue temp thermostat that starts the loading unit. Found these neat little LED indicator lights at the supplier, this one is on when there is electricty being sent to the loading unit:
I've got it set to turn the loader on at a bit over 100c exhaust temp. The power for it though also runs through a 6006 aquastat (in fresh feed parts pic above with cover off), so if the exhaust temp thermo fails for some reason, it will also start the loader when top of boiler water gets to 185f or so. That was Deans suggestion and it works great.
This kept me up way past midnight a couple nights ago and was the biggest pain so far. It's on the supply return line (so no heat to rads). After several unsuccessful attempts at stopping the leak in the very rear of the bottom of the 45 fitting by soldering upside down in place, and one quick grab for the garden hose, I ended up cutting a big section of piping out with the recip saw after discovering I had an extra coupling & union left over. I should have done that right off the bat. Took 2 minutes to resolder the leak once I had it out in the open & right side up, and a half hour or so to get the piping back in place & re-do the joints:
So the big event was Monday night - first fire. It took me a while to get a fire going - the refractory was way wet (it looked dry but I couldn't believe the water that was running out the bottom once the heat got going), everything was ice cold, and it was fairly warm out. There was no draft registering on the manometer at first. And I was in a hurry so didn't build it very good. But after a half hour of coaxing, and getting the draft to build, we had this:
I stared at that for a good hour. SInce then it has been a lot better. I was just down an hour ago to do another short burn (they've all been small loads so far), and took this sequence. Did a quick clean & unearthed not many hot coals (last fire was a small one this morning). Split some fine stuff, layer with paper then more wood. By the time I got that done, the paper was smoking:
Note no smoke outside. It all gets sucked in through the bypass and right up the chimney. No smoke in the house and no smoke hood required. I looove that. Manometer was about 0.05 before fire.
Then I grabbed the torch, and aimed:
Before I hit the trigger, flames erupted in the fire box, so I put the torch down & snapped another quick pic:
Closed the door and waited 5 minutes while I took some of these pics to close the bypass & start the gassing.
So, I've been heating the house and DHW by gassification since Monday, and the only electricity being used is what is running the 15-58 on low on the loading unit when burning. Even then I think it would all circulate by convection without that running - say in a power outage. With the tanks hot in the basement and uninsulated, the first floor & basement maintains. If I need heat in the second floor, I just manually open a couple of zone valves for a while. Next thing to do is get all my controls wired up so thermostats will be functioning again, and backup is functional. And put more wood in if we can get a few days with no rain (that's the priority). So far, I am marvelling at the way this thing works and burns all by natural draft. I think I had 0.05 on the manometer in the first gassing pic above. The unit specs for 0.08, I'm usually around 0.1 - my chimney is about 30ft. tall. I put the barometric damper back in mainly for winds. I think it would gas quite good enough on less draft than spec'd.
That took way longer than I thought it would...
![My Varm project... My Varm project...](/talk/proxy.php?image=http%3A%2F%2Fi1197.photobucket.com%2Falbums%2Faa423%2Fnsmaple1%2FHeavyfuel.jpg&hash=e973e77600ac74fcd9b31e3b640fd119)
![My Varm project... My Varm project...](/talk/proxy.php?image=http%3A%2F%2Fi1197.photobucket.com%2Falbums%2Faa423%2Fnsmaple1%2FInProgress2.jpg&hash=25b00e1ca887d363ce63bd63738ba878)
![My Varm project... My Varm project...](/talk/proxy.php?image=http%3A%2F%2Fi1197.photobucket.com%2Falbums%2Faa423%2Fnsmaple1%2FFront1.jpg&hash=19a435d726aec259908ee8055280abbb)
![My Varm project... My Varm project...](/talk/proxy.php?image=http%3A%2F%2Fi1197.photobucket.com%2Falbums%2Faa423%2Fnsmaple1%2FSide1.jpg&hash=2596dbc7e10d62a754a86173c9c279fd)
![My Varm project... My Varm project...](/talk/proxy.php?image=http%3A%2F%2Fi1197.photobucket.com%2Falbums%2Faa423%2Fnsmaple1%2FRear1.jpg&hash=8a57f82a30f2a7848ccd7a75ed516e5e)
![My Varm project... My Varm project...](/talk/proxy.php?image=http%3A%2F%2Fi1197.photobucket.com%2Falbums%2Faa423%2Fnsmaple1%2FPipingbottom.jpg&hash=32d9e8e4ccbb0e373c8a608737bf3921)
![My Varm project... My Varm project...](/talk/proxy.php?image=http%3A%2F%2Fi1197.photobucket.com%2Falbums%2Faa423%2Fnsmaple1%2FPipingtop.jpg&hash=2c20cbab9bfdd85ed66d1316745d4537)
![My Varm project... My Varm project...](/talk/proxy.php?image=http%3A%2F%2Fi1197.photobucket.com%2Falbums%2Faa423%2Fnsmaple1%2FSidearm.jpg&hash=96efea9e389d7495d9cddd4ea4e05142)
![My Varm project... My Varm project...](/talk/proxy.php?image=http%3A%2F%2Fi1197.photobucket.com%2Falbums%2Faa423%2Fnsmaple1%2FExpansion2.jpg&hash=6cc67837bf0f7d137cf4248ba48cccd0)
![My Varm project... My Varm project...](/talk/proxy.php?image=http%3A%2F%2Fi1197.photobucket.com%2Falbums%2Faa423%2Fnsmaple1%2FExpansionexisting.jpg&hash=e09965a8d87f4db32b0684cbee5abd59)
(Not a good pic).
![My Varm project... My Varm project...](/talk/proxy.php?image=http%3A%2F%2Fi1197.photobucket.com%2Falbums%2Faa423%2Fnsmaple1%2FLoadingLight.jpg&hash=096f2305861f0f91f50f8db65cbe961e)
![My Varm project... My Varm project...](/talk/proxy.php?image=http%3A%2F%2Fi1197.photobucket.com%2Falbums%2Faa423%2Fnsmaple1%2FFittingPain.jpg&hash=86065d5c1357c071b3f97d0d73f7690d)
![My Varm project... My Varm project...](/talk/proxy.php?image=http%3A%2F%2Fi1197.photobucket.com%2Falbums%2Faa423%2Fnsmaple1%2FGassing1.jpg&hash=0757bb1978e975ea89846ded4ffef6ae)
![My Varm project... My Varm project...](/talk/proxy.php?image=http%3A%2F%2Fi1197.photobucket.com%2Falbums%2Faa423%2Fnsmaple1%2FFire1.jpg&hash=3435342bb10281d1c0f9018dfc860b4c)
![My Varm project... My Varm project...](/talk/proxy.php?image=http%3A%2F%2Fi1197.photobucket.com%2Falbums%2Faa423%2Fnsmaple1%2FFire2.jpg&hash=8b13005fcfdc22416b19ff1f08699688)
![My Varm project... My Varm project...](/talk/proxy.php?image=http%3A%2F%2Fi1197.photobucket.com%2Falbums%2Faa423%2Fnsmaple1%2FFire3.jpg&hash=e453ef1362d1fa8e92d27eebcd39bdec)
