Had this little fella fall 2 years ago - I finally got around to cutting her up.
http://tinyurl.com/btntbb
what size bar you running on that 046captjack said:Had this little fella fall 2 years ago - I finally got around to cutting her up.
karri0n said:How do you split something like that?
Wet1 said:The fun way to split that is to turn the saw 90° to how it's pictured and run it down the length of the tree...
smokinj said:what size bar you running on that 046captjack said:Had this little fella fall 2 years ago - I finally got around to cutting her up.
thats what iam running, just trying to see how big that tree is. nice work!captjack said:smokinj said:what size bar you running on that 046captjack said:Had this little fella fall 2 years ago - I finally got around to cutting her up.
Its an 046 with a couple of tweeks with a 28inch bar. I normally have a 20 inch bar on it.
KarlP said:Wet1 said:The fun way to split that is to turn the saw 90° to how it's pictured and run it down the length of the tree...
repeatedly with the Alaskan mill set to ~2 1/4" thick each time. Then cut each of those planks in half again on the bandsaw to make a whole lot of 1x12 and 1x(whatever's left) rough oak lumber. Then put spacers between each plank and let it sit for a year or two. Then run it across a jointer, through a planer. Then a miracle occurs and you have a diningroom table and matching sideboard. ;-)
captjack said:The splitting part has become a bit of a problem. I think I am going to try and get the JD tractor back there and scope up 2 slabs at a time in the bucket. Not sure the tractor will be able to get to the tree. The other option is to get some wedges and try and split them there. I bought a 2.5 lbs fiskars the other day - haha but its not doing the trick !! If i can get them in hlalf i can manage them a lot better.
