iceman said:
Webmaster said:
This holds true with most inserts - that a sheet metal block off plate and very loose (or no) front panels will result in better performance and more heat. It's just physics - heat trapped back in the fireplace will tend to be lost if the fireplace is partially exterior.
I'm sure you will get a lot of heat, but adding some is always nice also.
thats funny you said most, i took off my panels and didn't really notice a difference!
Ice,
the Summit has an outer case (gray outer box) so the hot air is mostly between the insert itself & the outer casing. You then have the top are open where the blown air comes out, and the side grilles, so you have no need to take the surrounds off on this insert. Many other inserts do not have the casing, then it might be beneficial to take the surrounds off.
As to the person that is purchasing an insert without the blower:
Anyone that listens to a dealer about not needing a blower on their insert, is just naive. When its below 20 out and your wondering why your not getting the heat you expect from the insert, buy the blower, put the blower in, then you will understand why I am saying this.
Why do so many folks decide to drop a big chunk of change, and not research what they are getting and how it performs. I would never go by dealers advice alone.
Keep in mind, adding a blower after installation may not be so easy. You might have to pull the insert back out depending on the insert. Certainly easier to have it installed prior to complete installation.
