My Smoke hood
do you have any pictures you coul post?
Here is a pic of my hood setup
  • [Hearth.com] My Smoke hood
[img[/img]
i split most of the soft wood and the hard wood i keep round unless its unmanagable. the wood inside is my fire starting stuff. its 95* in the boiler room so it dries it real good.
taxidermist said:
Medman said:
I have tried the EKO draft inducer and also a high-volume range hood. The problem is that even 400 cfm is not enough air movement to pull the smoke out when loading or opening the door to knock down a bridge. I am looking at other options now also.
That is why I went with this.
(broken link removed to http://www.homedepot.com/h_d1/N-5yc1vZ1xhv/R-100072633/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053)
See any reason why that wouldn't work as a wall mount?
Huff
Huff
Should work fine
Just wondering, instead of trying to suck the smoke "out" once the feed door opens, is it possible to have a wall mount fan that blows air "into" the room to sort of create a positive pressure and keep the smoke forced into the firebox?
Pat
