Amsoil packages Sabre Pro in 1.5 oz "pillow packs" (basically a plastic bag) which actually works out close to 85:1 if you get every last drop out of them. Rinsing those packs with gas is quite a bit more trouble than a 2.6 oz bottle like most premix oil comes in. So you get a mix that's somewhere between 85:1 and 100:1 unless you leave a lot of oil in the pack. When I was mixing out of 2.6 oz bottles, I always rinsed the bottle 2x with fresh gas to get as much oil out of it as I could.
http://www.amsoil.com/shop/by-product/motor-oil/2-stroke/saber-professional/?code=ATPPK-EA
Worth montioning that for those of you that run Stihl's 4-Mix engine, that engine gets real happy running on a lean synthetic mix. Carbon build up is that engine's worst enemy (think of those itty bitty valves in there!) . Stihl's HP ultra is a great oil but honestly I like the Sabre Pro better at this point. Long term wear characteristics remain to be seen but after running a few different engines and re-tuning them, I'm a believer in the Sabre Pro as well. Of course AMSOIL says if you feel better running it at 50:1, you're more than welcome to do so as it won't hurt anything.
Also, if carbon build up is becoming an issue in your equipment, Stihl sells a "de-carbonizer" that works quite well and doesn't require disassembling the engine for cleaning.
