wendell said:Probably about 30 minutes since I engaged the cat, turned it down to .5 (using the top of the handle as the reference) about 10 minutes ago.
Top at 500, flue at 275.
Slow1 said:wendell said:Probably about 30 minutes since I engaged the cat, turned it down to .5 (using the top of the handle as the reference) about 10 minutes ago.
You raise a good point there - "using the top of the handle as the reference" - I always use the point where the handle actually intersects with the vertical metal of the gauge to determine where I am at. Experimentally I found that the min I can do this way is 0 and max is 5 so I figured that at least for my stove this was perhaps the best standard reference.
Based on your temperatures I would say you have the cat burning - have you been able to look up in there and see it glowing? Just wait til you see the reflection of the cat on the floor - that is a nice sight!
Yep, I reload after pushing most of the coals forward towards the glass, works great. I don’t think it matters if every bit of wood is charred before lite off, but I know what your saying about the fire not coming around to the front during bypass and I think sometimes you need to turn the air down more so all the flame doesn’t get sucked up the pipe out back.
MacPB said:Yep, I reload after pushing most of the coals forward towards the glass, works great. I don’t think it matters if every bit of wood is charred before lite off, but I know what your saying about the fire not coming around to the front during bypass and I think sometimes you need to turn the air down more so all the flame doesn’t get sucked up the pipe out back.
Todd, you reminded me of a question I had regarding the flames:
I've noticed on a video that was posted a while back that showed the flames (while the cat was engaged) going from back to front. Sometimes I see the exploding flames in my Fireview either go straight up or more towards the back of the stove. If it was not a new stove (bought Fall 2008), I would think that there was a slight gasket leak in the bypass.
Which direction have you noticed the flames going in? Towards front(where draft is going through cat) or straight up?
Mike
wendell said:Still trying to get used to all this heat with no flames in the last several hours of the burn. Do you turn your air up later in the burn or just let it go until it is time to load?
Slow1 said:Wow! Good to know that can happen, I didn't realize it could get that hot so quickly and I certainly wouldn't have expected it without the flames, but your theory does make sense to me. So in this case do you think that a little more air (to keep flames in the box) might have kept the cat cooler?
