following this as I wonder if this unit is the 42 Apex........FWIW, I do vacuum our cat when we cool the unit to clean the glass (WEEKLY). Please tell me this isn't another thing we are going to have to replace and wait forever under warranty. THis fireplace is becoming a huge joke
The issues being seen by the original poster in this thread are not common. We’ve seen this before, so I won’t say it’s completely unique, but it is not common.
Install per the manufacturer’s spec, follow the operating manual, and run your stove on dry wood, and you’re unlikely to have any such problems.
Getting back to this thread, there are a few open ends, unless I’ve missed their conclusion:
1. Lopi does not specify any minimum draft, maximum draft, or even optimum draft numbers. Nothing. Useless.
2. Other cat stoves often indicate numbers around .05” - .06” WC (can
@BKVP tell us why?). If this were my stove, I’d want to check draft under a high burn (hot chimney), and verify I’m not too awfully far from .05” WC.
3. The OP posted single-digit MC% numbers for his firewood, and this is just not possible, unless he is burning kiln-dried lumber stored in air conditioning. The Equilibrium MC%’s for most of the lower 48 are in the low- to mid-teens, when stored in a shed, so this is as good as it is going to get for most people. More often, people are burning around 20% - 25% MC. We need to get a real sense of the wood quality.
To properly measure moisture content:
1. Wood must be at room temperature, or you must use a correction table to compensate for difference between current wood temperature and 70F (where your meter was calibrated). Never try to measure MC% on frozen wood, it just doesn’t work.
2. Wood should be split immediately before testing, and all testing should be on that freshly-split face (formerly, the center of the split).
3. You should test middle and a few inches from each end, on that freshly-split face. Average the three readings together.
4. You should repeat on at least a few pieces from your pile, to be sure you didn’t just end up grabbing an unusually wet or dry piece from your stock.
