Hey everyone. I decided to start a new thread that better explains my problem with some updated photos for your feedback. Thank-you to @begreen who has been interacting thus far.
The main issue as you can see is the insert is too big and protrudes past my existing mortar fireplace. I am hoping to build out with steel studs and cement board to frame it in. I am planning on finishing the hearth and face with tile.
I will be adjusting the hearth size to accommodate for the extra space needed to get the 18" from insert to combustibles. Not excited about this, but I want to do this right. Side clearances are perfect with lots of play room for tile and side mantel. Top clearances are great only requiring 36.5" from hearth to mantel.
I will be filling in the space above the circulating chamber with roxul, sealing all joints with furance cement, covering top of chimney outside with flashing and cap, running a 6" liner to the insert.
My biggest problem is... it doesn't fit!!
What should I do?
PS. bonus question, should I still install a fixing plate/block off plate to the inside to seal the chimney as well as the circulating chamber? (still need to grind out the old damper)
What should I do?
