It most certainly will damage it. There’s a reason the water returns at a certain tempCirculating cold water through the boiler while the boiler is not running won't damage it? I can certainly modify my setup to active the circulator only.
How will it damage it? It won't be that much cooler than the water that's already in the boiler.It most certainly will damage it. There’s a reason the water returns at a certain temp
Same here. We just installed heat pumps (without auxiliary heating strip, which consumes too much power and even less economically efficient than propane boiler) and also have a wood stove. When it is below 20-25F outside, the heat pumps are much less efficient and could not keep up the heat loss even when running 24/7, so we need another heating source. I am trying to minimize energy cost and also protecting the pipes from frozen.I frequently torture myself figuring out the best mix of oil, wood, and minisplit usage.
Fortunately(?) my insert is not big enough to stop the heat from coming on during the cold snaps.
Why not get a clock thermostat and set the heat to come on from 3 - 3:10am for example?
Ours was a simple replacement of the boiler's analog tstat with a programmable one from Honeywell, like RTH2300B. It allows you to set multiple on/off times for each day of week. I am the sole operator of the insert, so the minisplits get run when I'm not home and the outside temps are solidly above freezing. No fancy tstats, press the button if you want to use them.Same here. We just installed heat pumps (without auxiliary heating strip, which consumes too much power and even less economically efficient than propane boiler) and also have a wood stove. When it is below 20-25F outside, the heat pumps are much less efficient and could not keep up the heat loss even when running 24/7, so we need another heating source. I am trying to minimize energy cost and also protecting the pipes from frozen.
What kind of clock thermostats are you referring to? We have the fancy Ecobee tstats to control the heat pumps, but I am having a hard time to control propane boilers with Ecobee since it does not have common wire and our Taco zone valve relay board does not seem to have common connection point either.
Thanks. Most of our old tstats can program four time periods each day with different temperature preferences. The problem is I am not sure what temperature it would require to trigger the call for heat. I guess I could set a temperature high enough (say 80F) to call for heat for one short period (5 mins?) and another temperature low enough (say 50F) to avoid heat call. But some thermostats have "smart recovery" which would initiate heat call ahead of time, causing unnecessary energy waste.Ours was a simple replacement of the boiler's analog tstat with a programmable one from Honeywell, like RTH2300B. It allows you to set multiple on/off times for each day of week. I am the sole operator of the insert, so the minisplits get run when I'm not home and the outside temps are solidly above freezing. No fancy tstats, press the button if you want to use them.
The drastic change will crack the heat exchanger. It’s not made to have cool water running through itHow will it damage it? It won't be that much cooler than the water that's already in the boiler.
What do you use the PID controller for?A PID controller along with an immersible K type thermocouple can probably do the same thing. I’m doing something very similar with my geo system and OWB.
I do like the SmartHome idea since you’d be able to possibly manage it remotely.
But there is no change. The boiler is off.The drastic change will crack the heat exchanger. It’s not made to have cool water running through it
I use a PID controller to break Y1 on my geo based off of the temperature of the incoming water. Not sure if could do something similar.What do you use the PID controller for?
To manage heat call remotely, one would only need a Wi-Fi enable thermostat. But the smart home hub could do more, for example to trigger the boiler (via smart thermostat) automatically when a temperature sensor reaches a threshold.
And any damage to surrounding areas from the leak.Just go the easy way and run glycol in the system...
Unless you have storage that is the fail safe way to protect
Lets say that you go with a programmable sytem to move the water,
What happens if there is a prolonged power outage like whats happening right now in eastern Canada and parts of the States due to extreme weather?
With no storage in play i will bet that the bill for the plumber would have paid for glycol.
