Why not use a 110V 1500W water heater element? You would obviously need a control thermostat on it, but it could be integrated right into the system.
(Whoops, probably not what you meant since wattage varies as square of voltage, so 1/2 the voltage yields 1/4 the wattage, or 875 watts in the example.)If you run a water heater element, you can simply supply it with 120V instead of the rated 240V and half the wattage. Get a cheap 3500W element and it becomes a 1750W. ...
how many watts do you think are needed? You're talking much higher numbers than the original 60 watt bulb contemplated above.
I am not sold on running the circulator 24x7. Plus, I don't want the lp boiler to heat the owb on a regular basis, and with my current setup that's what would happen if the owb circulator was running while the lp boiler was in operation.
I really like the simplicity of a water heater element and thermostat, assuming the tstat has an anti freeze setting. It's cheap, reliable, simple, and effective.
Efficiency is not top of the list for anti-freeze technology. It may never actually be utilized and it only has to keep the water above freezing. The difference in efficiency between a 100 watt element heating 900 pounds of water 3 degrees vs an 800 watt element is likely negligible. And all the parts for the 800 watt setup is redily available from Home Depot.
I appreciate everyone's opinion and input.
As an off the wall idea, for truly emergency protection, you could tee in a zone valve to one of the lines hooked to a thermostat that would just dump the water if it's getting close to freezing. Water's pretty easy to replace![]()
Even with heating element(s) in the boiler, without a circ running won't you still have an issue with the outdoor lines freezing up? Or do you expect to get enough natural cycling to curb that?
