I've had my geospring installed and running for about 6 days now, so I thought i'd add some of my initial observations.
I purchased the unit from lowes at $999, used a 10% coupon to tack on the 10 year labor warranty extension which brought my final price back to 999+tax. I qualify for $400 from my local utility and used discover card to get another 5% cashback.
We have the unit set to heat pump only mode (125F) and it is installed in my unfinished and unconditioned basement which stays 55 to 60 year round (the basement is completely underground). The unit typically runs 1 to 2 hours after a shower to recoup the heat loss and the heat pump operates around 600 watts. When running, the air coming out of the condenser is about 15F lower than the ambient air. I have it in my utility room (where my oil boiler also resides, albeit turned off) which measures approximately 12 by 14 feet. The door to the room is open, and my thermometer in there typically measures a 1F drop in temperature after the heater performs a recovery run. The temperature normalizes within 15-20 min after its been off.
I'm currently using a 5 gallon bucket (pictured) to collect the condensate (which we just use on the potted plants). The amount of condensate pulled will vary on the ambient conditions and use, but given what I have collected I suspect it will take me about 3 weeks to fill a 5 gallon bucket. Its just me and my wife at home.
As for the noise, we don't notice it upstairs at all. The only time I can hear it running upstairs is if the basement door was left open. It is no louder than modern day dehumidifiers (my reference point is a fridigaire dehumidifier). It does sound like a small a/c when running.
I live in southeast PA and after purchasing the unit I filled out the online form for the rebate through my local utility (PECO). For those who have PECO, you do not need to have your generation portion from PECO in order to qualify for the rebate, just have to be a PECO customer in good standing. About 2 weeks after submitting the application, I got a call from PECO that they wanted to perform an in house inspection (about 5% of applications are selected, what I was told). The inspection was rather painless and brief. Someone came and looked at the unit, took a wide picture and then a picture of the serial number and barcode on the unit. I should be getting my rebate in about 4 weeks.
![My Geospring My Geospring](https://www.hearth.com/talk/data/attachments/133/133405-f0f4876b425d9bf27429705819eb07a6.jpg)
