north of 60 said:
Those #s are only good at sea level. People that are at 4000+ are gonna have a different story along with results. Time to de-rate those #s. Oil and gas #s will show significant change at 2000 and up.
Everything changes up high.
Most easy to measure would be draft. A chimney at 1 mile high will have 20% less capacity and a lower static draft than the same chimney at sea level. What would that mean regarding super-dry wood? I'm not at all certain, but I can think of one scenario. With reduced draft, residence time for flue gases would be longer. Adding a bunch of small splits of extremely dry wood onto a raging bed of coals could lead to a system packed with smoke.
Even if you opened up the air all the way (which can lead to some nasty backpuffing), there would still be denser smoke in this system than in the same one operating at sea level. It's totally possible that not enough air could be introduced to completely burn off this smoke. As well, there is less oxygen at those levels, so you would need even more air volume introduced for combustion to be complete. This could exacerbate the problem. Lower draft will also mean lower intake velocity, reducing the mixing effect of turbulence on air and wood gases, leading to incomplete combustion. If you can get the fire hot enough, the higher flue temps will increase the draft (and therefore, the intake velocity), resulting it improved combustion, but then more heat goes up the chimney. All things considered, not an efficient and controlled burn.
All hypothetical, I've never burned above 2000'. Maybe Beetle-kill can give us his observations at 8000'? ;-)
My feeling on the subject it that if you put a big load of kiln-dried pine cutoffs or split 2x4s into a hot stove, you are going to have problems, like creosote formation, lower temperature burns, severe backpuffing, and wasted fuel. If you put large splits or rounds of dense super-dry hardwood into the same stove, pyrolysis will occur much slower and the stove should be able to handle it no problem if you give it enough air. The answer lies in experience and observation, and not in a set of absolutes. But I personally think it's good to let new burners know that dry wood alone won't solve all their burning problems, and that in some instances, drier wood wastes more wood through smoke than less-dry wood.
Stoves are designed for wood around 20% MC, stoves are tested with wood around 20% MC, so it stands to reason that 20% MC should not be considered to be merely adequate, but rather, the ideal.
