Hello All,
I'm new to the forum so hopefully I'm doing this right.
I have an Englander 25-pdv and its manufactures date is in 2004. I bought it last year on craigslist, and it worked like a champ at first. I clean it as usual and I have cleaned the flue piping and checked all the vacuum lines and no cracks. I replaced the gaskets on the augers when one jammed so I replaced them both, top and bottom. The pellet stove will not stay lit. Before the pellet stove would die out and then the burn pot would fill with unburned pellets so I found the vacuum hole and cleaned that out, and it worked for a cycle (about 2 days). Then I cleaned it and went to start it, now the fire start but takes forever to start. The pellets don't seem to be feeding into the burn pot. When it finally fills up it smokes for a while then the fire finally lights, but its a dull fire. Doesn't seem to be burning as hot as before. Before you could hear the flame and watch it burn fast and hot. So I leave it and then the pellets just burn and then it dies, and no more pellets get fed to the fire. Any thoughts on this? I have yet to grease the bearings and the auger motors.
Let us know how you make out...
