Ok I'm back...
Got lucky and won a 066 OEM P&C on ebay...So I went ahead and ordered a set of Caber F-Cast rings...
Now I was prepared to have to make this fit..Open the case for the skirt and open the holes for the head bolts , BUT to my surprise the piston fit just fine..Ok cool lets see how far off the head bolts are wait they line up too????????????
Yup for some reason it fit with no modification at all...
Ok so for parts thus far...
STIHL 064
Replaced parts list..........
part # 3591220 oil cap sealer ring
part # 11227909905 annular buffer
part # 11220292301 cylinder gasket
part # UPARTS muffler screen
part # 3591230 gas cap sealer ring
part # 11227909102 hand guard kit
part # 11251490601 exhaust gasket
part # 90223411050 spline screws
part # 11173505800 tank vent
part # 11271418600 impulse line
part # 3503504 pickup body (fuel filter)
part # 11221903400 elastostart assembly
part # 1124953500 rewind starter pawl spring
part # 11241957200 pawl (X2)
part # 11240071010 oil line kit
part # 90754784155 spline screw (replacemant for top cover)
part # 6421216 stihl 8 tooth rim
part # 11227909910 annular buffer
part # 7545 bosch ws7f (plug)
part # 1128209400 compression release
part # 00001 201654 air filter
part # CRF 5412 caber f-cast rings
part # 54zn12 mahle piston and cylinder 54mm
part # 1226567700 chain catcher
part # 00004050600 plug wire
part # 11224402210 ground wire
part # 11281291100 carb gasket
part # 11223510901 tank guard
part # 11221412201 manifold boot
stihl 064 plastic name tag
stihl starter rewind plastic tag
after market pnw sproket cover with chip guard
Ok so the 066 has a hole for a decomp valve and I want to use it but the top cover has no hole..After finding out that the 066 top cover is wider and wont fit right I decided to make a shroud for it myself...
Not my best but it works just fine..
Put it together and tried to set the carb and found out there was a hole in the manifold boot..got a new one today and now she runs sweet..Still need to dial in the carb but it is real close...
I'm still not done but that's where I'm at today...
Looking for a 066 factory type wrap bar..Also want to get a 9 pin rim...After that I'll see what else I get into...
So for this free running 064 I'm now real close to $400 LOL!
Thanks for looking
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
