my dealer said run it on manual and set it slightly lower as far as heat output goes. If your reaching the wanted room temp stove shuts down and then reignites. This on and off seems to lead to ignitor burn out.
I am currently in the middle of my 3rd heating season with a Quadra-fire Mt Vernon AE pellet stove and am wondering if anyone has any advice on what to do about a pellet stove that burns out ignitors way too often. My first season, the ignitor failed 3 times. Last year, at least 3 times and this year it just failed for the 3rd time and there is still lots of winter left up here. I cant even get through a ton of pellets without a failure. I clean the stove 2 or 3 times a week. I have the updated firepot, a new wall control, a new baffle.
I could tolerate the hassle of these failure until my warranty expired recently but, given the problems I have experienced with this stove, I dont really feel comfortable going through another heating season without warranty protection unless someone has some ideas on what could be going on with this stove that would cause these ignitors to fail so frequently. The dealer has, in general, been good to work with and seems willing to go to bat with Quadrafire on my behalf so we will see where that goes but I am wondering if anyone else has had ideas about what could be going on and how to fix??
Escpecially 06 models. Some folks say venting configuration affects ignitor life.AE sucks!
Let's see how good I am. Reading this post, I'm going to attempt to call out what kind of stoves you previously had....My wife and I love the pellet stove concept. They burn real hot and real clean. But this is our 3rd pellet stove and we just haven't found a reliable pellet stove yet. It's not like we're buying the cheap ones to save a dime, either. It seems that the fewer parts, bells, whistles and buttons on the stove, the more reliable they are. Our first pellet stove lasted one winter before the cast aluminum auger snapped in two. The replacement auger assembly didn't line up with the stove holes, even though the new steel auger came directly from the stove manufacturer. Our 2nd pellet stove had a blower problem and smoked up the house so bad that the fire department had to come and air out the house for 4 hours with their fans. We figured the 3rd time would be a charm with our AE but it's been a big disappointment as well. My wife is somewhat disabled and I am away from home a lot, so lifting a 40 lb bag of pellets was easier for her and my young son at the time. Now that we have our own land out in the country, and my new job this fall will have me home every day, burning free wood from our own land is the best option for us during our long, cold northern NY winters. Thanks for the feedback and insight. As we get older a pellet stove might find it's way back into our home if there's nothing better on the market by then.
They do. The one you had wasn't right. It had aluminum in it and shouldn't have.I would consider buying another one if they use steel augers.
First one was an Englander, not sure of the model number, but it was the most reliable pellet stove we had. That's why we went through the trouble of replacing the auger. Might have installed it in 2005. I would consider buying another one if they use steel augers.
The 2nd one, I believe it was an Avalon Astoria. Might have installed it in 2006. We didn't have it long before we had problems with it, maybe a month or 2.
What's your professional opinion of the 3 stoves I have owned?
I think you mean lower wattage.I am not sure i did not read all the posts so far, but we had a string of these going bad before we stopped being a quad dealer. The answer from tech was to change the fire pot out which i did (at the tune of alot of money out of pocket from customers) this did not help a few months later Was told that it was the voltage of the ignitor that had a problem and to change out to a lower volt ignitor.......Tech said the problem was in the stoves control board because it is a multi fuel stove the ignitor stays on much longer even after the fire has started.......We never did get a stright answer but the lower volt ignitors seem to help some![]()
Yes yes sorry just got off a long day put 15 hours in cleaning stoves and driving lol little tired atm
Today 12 with four hours of drive time![]()
In my preferred order...Englander, Astoria, Quad...darn I thought the second one was going to he Hudson River...wouldn't have thought Travis...
Englander makes a very good product. In 2005 they had some alloys that made their way into the foundry, your auger may have broke in two or even melted completely. Problem being, your problem happened at a time when they were changing the feed augers to incorporate a seal under the pivot bearing. Stove with this foundry issue were covered under warranty. They new steel auger they sent you may have been too short to accommodate the seals they sent you and when it was put back together, I bet you couldn't line up the set collar for the auger motor or you just were not adjusting the auger right within the tub. I run into this same exact issue 3 or 4 times a year with stoves from that foundry issue back in 2005.
Hmmm. the Avalon, also a great machine, has some issues with burn back, more so the samller version which is the Newport or Pioneer (Lopi). I'm partial to Englander because of their support and the cost effectiveness of them. Travis is very difficult to deal with all around for me but I like their stuff.
I loves quads...jsut not the AE. They sell a lot of them but I do not think anyone knows how they work...including me...and I know a lot. If I don't mind me saying![]()
I liked the simplicity of the Englander, no thermostat, just heat level buttons bumbered 1-5. After the replacement auger wouldn't fit, we were able to get a full refund, so I agree that the Englander customer service was very user friendly! We found out a year or two later that they went to a steel auger.
It was the fall of 2006 when we went with the Avalon. We loved the stove but the shop we bought it from refused to come out to the house to see why it was filling our house with smoke. It started out as a small problem that would clear itself up. And then one night the smoke in the house was too thick and set off our house alarm, which also dialed 911. The fire captain found out that the stove installer refused to come out and replace or repair the stove several times and it turned into a heated battle between the fire dept and the store owner, who claims it was a faulty exhaust fan. I understand there are lemons in every good company. It seemed like a great stove but the store refused to honor the warranty (North Country Hearth and Homes). According to the fire captain, they had other problems and complaints with that business before us.
Then we bought the AE from Sundance Leisure, and their customer service is out of this world! Their repeated attempts to fix our AE is the reason we held onto it for so long. They stood behind their product and installation year after year, even after the warranty expired. But the last 2 or 3 years worth of repairs came out of my pocket, with little to no help from Quad. I'm tired of fighting with the AE, so we are going to use simple wood stoves that have NO electronics on them.
Sorry to hear that about your Avalon Astoria. I have had very good luck with mine. I think you would really like that new model englander EP-25. It puts out 22k BTU. Not sure if that would be large enough.
I was always leary of the AE because of ALL the electronics! More than any other stove I have seen!
I had year 2000 Quad Classic Bay CB1200. That was the best stove I have seen that can work well on a T-Stat!
I also had an Enviro Meridian. The prettiest charcoal color stove that cranks out alot of heat! It was 7 years old with NOTHING wrong with it!
I like to tinker with these stoves a bit and find out how they work. LOL
I also came across an Englander 25-PDV that puts out alot of heat. But it was never right from the factory so when I got it both auger motors were shot!
So I found the knit line on the cast iron auger had to be ground down on the top auger with my bench grinder. Then it turned without a snag. So I put 2 motors in for $120 and it was good as new! LOL
My friends made a video of me and the Englander 25-pdv LOL
see
