Hi everyone,
Stove season is over and cutting has started.
My Stihl MS290 starts fine and runs at full throttle but it won't idle anymore and dies as soon as the trigger is released. It's about seven years old, months before they switched to the 291, and hasn't had any issues or work done on it. It started idling lower a couple of years ago and would die after ten seconds but I never adjusted anything. I was bucking logs and everything was as usual. I had been working for a half hour and fired it back up after moving a few rounds and it was like the chain break was on and the chain wouldn't rotate. I shut it down, cleaned and loosened everything. The oil hole in the bar had sawdust in it and might have been clogged. Since it was stopped I figured I'd adjust the idle screw and turned the low side a bit. This is when the problems started. It wouldn't idle anymore. Below are the things I've tried or verified.
The air filter is clean.
New spark plug.
New fuel filter.
Good fuel.
No ethanol ever.
Seafoam was added for all of my "repair testing" about a half tank has gone through.
Spark arrester is clean.
LA adjuster screw has been dialed around without any benefit.
I pulled the carb. The screen was clean and the diaphragm looked ok and was flexible. I sprayed cleaner on everything and into the tubes.
After each of these steps I tested and there was no improvement at any stage.
The high and low adjustment screws just spin and don't have stops, not sure if that is an issue. I know they have protections to keep them within a safe range but everything I see says to turn until it stops and then back them off. Mine don't stop.
Any thoughts?
Thanks
New spark plug.
New fuel filter.
Good fuel.
No ethanol ever.
Any thoughts?
Thanks
