I think I'll fine tune it and call it good with what I've already done. It is an improvement over stock and that's good enough for me. Heck, just having the limiter tabs gone and being able to fully tune it is an improvement over stock!
ikessky said:Just an update. Took the saw out this AM and tested it and tuned it some more on some decent hardwood that my FIL had sitting in his pile. Once the saw started, I let it idle for a few minutes and then reved it a little so that I would be working with a warm engine and could get a good tune. Next I made some light cuts and then let it idle a little more. Finally, I cracked it wide open and got a nice little four stroking sound. I leaned it out, the richened it up until I was back to the four stroking/rough sound. Then, I went at some pieces of wood. Right now, when I got WOT, the saw four strokes. As soon as you get it into the wood, it smooths out until you pull out of the cut. So, from everything I can find, I should be tuned perfectly now.
ikessky said:Probably would have been an even more noticeable change had I sharpened the chain before hand! Can't wait to try a full chisel once I start cutting in a month or so.
ikessky said:Depends on how you do the muffler mod. On mine, the gases are still going through the baffle. It's a touch louder, but not very much. If you drill above the baffle and straight pipe it, then it will be quite a bit louder. In reality though, we should all be wearing hearing protection when running the saws.
southbound said:Thanks but I did not do it I had a member from another forum do it up for me...
southbound said:They came with the saw...
