MS290 muffler mod
ikessky
862
Northern WI
Well, after a having the saw for close to a year and doing a bunch of reading on muffler modding, I finally decided to go a head and do it. I should have taken some pictures, but didn't really have the time since the littlest one was chasing the dog around the garage while I was trying to work! Basically, I combined the two existing slots into one large opening. It's not straight piped like a lot of the ones you see, but I may take it apart again and add one or two small holes in that area. I sliced the tabs off the red limiter caps and the reinstalled them, set the L screw to about 1 turn out and the H to 1.5 and tuned from there. It's probably still a little on the rich side, but I didn't want to over do it since I didn't have a tach to use.
All in all, it wasn't a hard job and I might have picked up a little power from it. Hard to tell since I didn't really have any wood laying down to really try it out and I didn't want to go out felling trees with a 1-year-old tagging along!
Post up some pics when you get a chance....... there still may be a lot of gains left in the saw depending on the size of the opening
+1
So I should probably just add a few holes into the depression and tune it again? The mod I did still puts the exhaust through the baffles.
Here's how I did mine (and several others). I put the screen back in after the picture.
  • [Hearth.com] MS290 muffler mod
post a few pic's it will really help
I was running my saw, the 290, two days ago felling some junk trees. When shortening the stumps I noticed that the mufflers on these saws are very quiet. The intake suck sound is very loud. I expect that you could open up that OEM muffler quite a bit before even being able to hear it over the intake.
that looks good
heres mine
The exhaust is taking the path of least resistance right? So, I should be able to add a couple smaller holes in the depressed area above the baffle and not hurt anything right? If these holes cannot flow all the gasses, it will then take the path through the baffle. Is my thinking correct here?
hittensteel has it perfect I Would rather have one opening.
Not my picture, but this is basically what I did. My opening is straight across though. I didn't make the small vertical leg like this guy did.
That seems to be a popular way of doing it....Should work fine....
I got a 064 muffler that needs a pipe welded on the side....Gonna have to pay someone for that tho....
Now do you know how to tune it you opening should be enough?
I took my tuning process from the Madsen's site. Tuned the L screw to a point halfway between where it starves for fuel and where it loads up and runs the chain. Tuned the H screw to a point where it is 4-stroking at WOT no-load. Like I said before, I'm not sure but I might have it a little richer than it needs to be as I didn't think that the 4-stroking went away when I put it into wood. Then again, I tried it on a half rotted piece and a few pieces of 2x12 lumber.
your dead on track better to be on the rich side. Best to listen to it in the cut and make adjustment from ther if need be.
You should be able to notice a diffrence in the larger wood when the bar is baried
I'm going to open the slot up a little more and then do some more tuning when I can get into some actual larger hardwood. I think my FIL has some sitting by his OWB that he wouldn't mind me cutting, so that should help me out as I'm not going to be trudging through the woods in the snow right now.
A total of 1/2-9/16 opening is the sweet spot for a 55cc saw. my 460 is at 3/4 opening its 77cc
I assume you are talking square inch opening? Removing and reworking the muffler is pretty easy, so maybe I'll take it back off and do some measuring.
I am talking about the opening in the cover only
The deflector? Yeah, I didn't open that up a lot. I still could take some off of it to.
if your opening is line up with the deflector it should be as good as it gets
So do you think that drilling a hole in the depression would hurt now that I've opened the slots up? Would I have too large of an opening at that point?
get a measurement and see where your at.....?
