Man is that a JD stx 38 deck ?
sorry just quit while your ahead oh its' to late
just pulling your chain , hope your efforts pay off for ya!
cheers
 But I want one set up with a one bottom plow....
I've just got to try that stuff I guess. I've been resistant because of the cost and it would take a lot to coat my triple 61" deck.After you paint it all up, use the fluid film. It helps. I use it on my commercial mowers. It's not an end all solution, but it sure helps keep alot of it from sticking. Reapply it every month or so and all is well. On your tractor, use a set of car ramps and you dont even have to drop the deck. The spray cans are pretty pricey for what you get, so I buy quarts and use an old paint brush to apply it.
FWIW, it works pretty darn good on snowblower chutes too.
![[Hearth.com] Mower deck cleaning [Hearth.com] Mower deck cleaning](/talk/proxy.php?image=http%3A%2F%2Fecx.images-amazon.com%2Fimages%2FI%2F41HBGTBXPRL.jpg&hash=cb52042c63f36703c38a233333ddf0e5)
	I hook a heavy duty strap from the ROP bar to a tree. Creep the mower forward and do a wheelie until the front is pitched upward enough to access the deck. I then use a hose to clean it. This is a 2-3 times a year event, usually when I am replacing the blades. Otherwise I do the same thing to expose the blades and sharpen them while on the deck. Just a touch up edging with this:
Nice job Jay...
I have been forced to cut grass while it is sprinkling this year. (Baseball season and I got roped into coaching again)
This year is the latest I have seen the corn and beans go in the ground. I have to cut 2 times a week.
I clean my deck every chance I get with the scraper. Then hit the bottom with lube of what ever sort.
Sharp blades are the ticket. I cut everything higher in the spring.
Last year I think I only cut the grass 2 more time from this point on. exaggeration yes but not by much.
sharpen all 7 blades (14 edges)
WTH are you running? I thought you had a Deere 757, those were 3 spindlee machines last time I checked. 7 spindles is WAM (Wide Area Mower) territory....
Down to every 5 days now...was @ 3 to start the year.
Multiple machines... 3 spindles on Deere Z-757 60" deck, another three spindles on the Cub 123 48" deck (recently replaced with Deere 855 with 72" deck), and one spindle on my push mower. In the past, all three machines would get a yearly sharpening, but since I haven't been using the 72" deck (the Z-757 is faster and neater), I will be down to only four blades this year!
I was mowing roughly 5.5 - 6.0 acres last year, as I was trying to keep the property next to mine neat. I would use the Z-757 on my own property, and the Cub on the other property. Now that's sold, and I'm down to mowing less than 4 acres.
If that's a 48C on the LX277 it should mow waaay better than the LA 135.4 is what I am mowing now. 2 mine la 135 and 2 for my uncle lx 277. Mowing I think the 135 does a better.
42C should cut good too. Set 'em up 1/8" lower in the front than the rear. RPM's from the motor should be similar (the LX277 is very quiet compared to your LA 135). Could also depend on what blades are each deck. Best appearance will come from the high-lift or bagging blades.
Dealerships often don't take the time to set a deck up for best cut. Especially if the cust isn't complaining.
 Between me and the gf mowing we both would pick the 135 for mowing. 9135 has 280 hrs and the 277 has 300)
 Between me and the gf mowing we both would pick the 135 for mowing. 9135 has 280 hrs and the 277 has 300)That's crazy. The LX277 should be quieter and more comfortable in every way, costs 2x what your LA did too!
Don't make me come out there........
 So get out here we can race them lol
 So get out here we can race them lolI think Deere offered a suspension kit for those, even tho the stock seat is good. The pros know that the seat matters!My internal organs wish I would switch back to mowing with a tractor. I don't know how these guys who ride Z-traks all day do it! I hurt after just a few hours on mine, and I'm in good shape. Tried mowing right after dinner once, and felt like I should have obeyed the 40 minute rule for swimming after eating.
